Author Topic: CB750 F2 Primary chains  (Read 12171 times)
Offline archmill
« on: April 28, 2024, 08:57:14 PM »
Hello, Have at last started re-building the CB750 F2 as a cafe racer and started building the engine this weekend. The last time it ran was 1982 and the guy who passed it on to me said it dumped all the oil on his boots so he stuck it in a shed. Have stripped the engine completely so I am starting from scratch.
Measured the primary chains and got a size from the oil pan face to the tensioner of 69mm so I recon they are done. Bike had only 25,000 miles on it.
Where is the best place to get new primary chains and tensioner.
Any advice greatly appreciated.
Offline Athame57
Re: CB750 F2 Primary chains
« Reply #1 on: April 28, 2024, 09:05:43 PM »
I'd check out David Silver Spares for something like that. https://www.davidsilverspares.co.uk/
1978 CB400F2 named Elen.
Offline Martin6
« Reply #2 on: April 28, 2024, 10:47:31 PM »
Wear limit spec is 70mm. Does anyone know what this measurement is with a brand new chain?
Offline Athame57
« Reply #3 on: April 28, 2024, 11:17:04 PM »
If you place a primary chain upright and the top row sags to contact with the bottom row the chain is finished. As to how close you'll let it come to that I guess is up to you.
« Reply #4 on: April 28, 2024, 11:28:56 PM »
George, that only works on Hyvo primaries, like the 400/500/550's. 750 chains are different, they are not Hyvo, they are a lot thinner and there are 2 of them, side by side.
Offline archmill
« Reply #5 on: April 28, 2024, 11:55:58 PM »
Seemingly new chains have a measurement of 65mm, at 70mm they are done.
Offline archmill
« Reply #6 on: April 28, 2024, 11:57:36 PM »
Nurse Julie, how are you doing. You did the camshaft on this engine a few years back.
Offline Athame57
« Reply #7 on: April 29, 2024, 12:12:27 AM »
Ding dong....getting ahead of myself Julie!
« Reply #8 on: April 29, 2024, 07:00:12 AM »
When you replace. "To stagger or not to stagger ...that is the question"
I chose to stagger mine.
« Last Edit: April 29, 2024, 07:04:40 AM by AshimotoK0 »
« Reply #9 on: April 29, 2024, 08:26:56 AM »
Always stagger Ash, I like a good stagger 😂😂😂
Offline Skoti
« Reply #10 on: April 29, 2024, 07:35:02 PM »
Also there's reinforced heavy duty primary chains available that sag less than the standard original RK ones.
I think they are made by IWIS in Germany.
https://www.classiccyclecity.com/gallery/thumbnails.php?album=48
Skoti
1976 Honda CB750F1
« Reply #11 on: April 29, 2024, 07:39:47 PM »
Hi Archie. How are you, still fettling I see. Good on you.
Offline archmill
« Reply #12 on: May 11, 2024, 07:07:43 PM »
" Wear limit spec is 70mm. Does anyone know what this measurement is with a brand new chain? "
And the answer is 63mm. Brand new chains and tensioner from CMSNL.
