Author Topic: Replacement bearing for transmission 20mm needle bearing 91022333018  (Read 2889 times)
Offline Dolomite_
I've decided to replace all the bearings as the gear selector bearing is pretty rough and the engine is stripped so I may as well.
I can't quite find a bearing for part 91022333018. In the parts manual its bearing, needle, 20mm. On PDF page 25 (https://www.dropbox.com/s/7pieydvznvy7nhp/CB350_F_F1%20Full.pdf?e=7&dl=0) its showing as a bearing inside a metal cylinder, does the bearing come out and a new one slide in?
I know its 20mm but don't know the other measurements. Has anyone found a replacement?
« Last Edit: May 01, 2024, 06:55:35 PM by Dolomite_ »
Online McCabe-Thiele (Ted)
