Author Topic: A hunt for seals  (Read 8680 times)
Offline Athame57
A hunt for seals
« on: May 04, 2024, 03:37:40 PM »
I'm on a hunt for some seals, and I don't mean with a club either!  ;D When I had my recent engine rebuild done, they mechanic told me that the large seal for the oil pump wasn't in the seal kit I had supplied. I got that part from DSS no problem but it turns out there are some very small seals that also ought to be changed (why not say before?) as I've still got some leaking I'll endeavour to get them.
They are parts 285 and the twice numbered (?) 286/7 0n the CMSL diagram I've posted here. https://www.cmsnl.com/honda-cb400f-england_model14639/partslist/E01-3.html  .
The seals numbered 285 (part # 91302044013) on the picture I can get from DSS as they are in stock, but 286/7 isn't in the associated parts list on the CMSL page I just linked, so I can't pull up the proper part number/s to put into the DSS search box, so I'm stuck. Can anyone help?
1978 CB400F2 named Elen.
Online McCabe-Thiele (Ted)
Re: A hunt for seals
« Reply #1 on: May 04, 2024, 03:49:22 PM »
Julies kit contains all the O rings for a 400.
Offline Athame57
« Reply #2 on: May 04, 2024, 03:51:04 PM »
I'll remember that for next time, but well, y'know... I'm only after two little ones!  ;)
« Reply #3 on: May 04, 2024, 04:01:34 PM »
Might be worth asking Julie I believe she assembles the kits from her stock of Ob rings.
Offline Athame57
« Reply #4 on: May 04, 2024, 04:22:35 PM »
Will do. ;)
« Reply #5 on: May 04, 2024, 06:03:46 PM »
Julie sells her full kit seal kit for £13.75 and she gives forum members a bit of discount so well worth the money especially when you consider I recently bought two genuine Honda o-rings (oil gallery plugs) and they were £7 and £5 respectively!
I'd buy the full set and then you'll have some spares 👍
« Reply #6 on: March 01, 2025, 04:05:14 PM »
Old topic I know but the info may help someone searching for this in the future.
The missing part number on the CMS website does appear on the same website if you search another model, the USA version of the 400-4 has a different parts book, laid out in a much better order, more like it should be IMO, this parts book lists the missing number.
https://www.cmsnl.com/honda-cb400f-super-sport-400-four-1975-cb400fk0-usa_model444/partslist/E++12.html
For info, the size of the missing part is also shown and is readily available on Ebay etc. The other dowel ring shown as 6.9 x 1.5mm however isn't. You'd need to either buy genuine Honda or have them specially made, same for the large ring at 62.4 x 2.5mm, the one missing behind the cover is I believe available from Honda as part number 91303-377-000 and is 13.8 x 2.5mm, again not a readily available size and special order to have them made.
« Reply #7 on: March 02, 2025, 01:39:35 PM »
Legendary sleuthing there Fester
Offline Man Of Kent
« Reply #8 on: March 07, 2025, 05:10:28 PM »
Hi, does Julie still do the O ring kits?
« Reply #9 on: March 07, 2025, 05:13:49 PM »
Yes, I still do the kits 😊😊😊
Offline Man Of Kent
« Reply #10 on: March 07, 2025, 05:17:59 PM »
Hi Julie, just sent you a message.
« Reply #11 on: March 07, 2025, 06:09:32 PM »
Many thanks Dave.
