Author Topic: Rear wheel rotation stiffens up when tightening axle problem.  (Read 4686 times)
I had a second wind this evening so with the rear wheel in position, no brake shoes binding, attached the brake anchor bar to the hub.
With the axle nut loose the wheel rotates freely, as I tighten up the axle nut the wheel is stiffer to turn so something must be amiss.
It will rotate by hand but with much more effort.
The axle shaft fits easily through the hubs etc no force needed.
The fixed bearing was fitted without issue with the small spacer and the long spacer in position
Right hand bearing knocked in easily.
Left & right spacers in the correct position.
I haven't as yet fully torqued the axle nut wtf is going on?
Is it possible that the right hand bearing is not full against the central long spacer so it might improve the situation at full tightness?
I can't seem to find a picture in the parts book for the fitting of the rear brake hub anchor parts or what way round the shouldered bolt should fit - is it with the split pin on the inside or facing out?
« Last Edit: May 05, 2024, 11:57:33 PM by McCabe-Thiele (Ted) »
Offline DomP
Re: Rear wheel rotation stiffens up when tightening axle problem.
« Reply #1 on: May 06, 2024, 08:05:44 AM »
I can only think that it's tying up on the bearing Ted, maybe you need to drift it in ever so slightly more?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #2 on: May 06, 2024, 09:18:23 AM »
Could be Dom, ill remove the brake hub and give it another thwack with the drift.
Update: The right hand bearing was not flush with the hub face - it did not want to knock in any further so I undid the lock ring on the left side and it's now flush with the face.
Now the lock ring is not fully against the drive hub so I guess I might need to tap the left side bearing a tad more from the left side.
Not sure if there should be a gap between the lock ring and the drive hub. Mine is probably about the thickness of a Junior hack saw blade between the lock ring and drive hub face .
« Last Edit: May 06, 2024, 11:05:18 AM by McCabe-Thiele (Ted) »
« Reply #3 on: May 06, 2024, 11:50:07 AM »
Unsure if I've understood correctly the current adjustment just made Ted.
The left bearing, with retaining ring has only one true position which is "fully" located in it's accompanying architecture.
This is the wheel datum (same on front too) for the rim alignment in the chassis, with all other spacing etc slaved off this installation.  Bearing race fully home and retaining ring fully tightened is the only method, anything else with compromise doesn't take precedent over this procedure.  The other parts and alignment should be looked through for fault if it exists then.
If the primary, LEFT bearing isn't secure in it's location, then the wheel can move across the axle during use  :o to the detriment of competent running and risk of jamming the wheel in cases of significant movement.
« Reply #4 on: May 06, 2024, 12:43:30 PM »
Good point I'm going to get the fixed bearing fully home as it was before. I'm thinking the right side will move back out a little but not as far out as it was.
I understand the fixed bearing principle - the lock ring seems to have two functions. Securing the fixed bearing and holding the drive hub fully home.
Update:- I removed the lock ring (again) and using a drift with a good sized lump hammer the left side bearing is fully home. The hammer strike changed tone as it butted up to the recess. Drive hub and lock ring fitted back and it's fully tightened with no gap visible between the ring & hub face. Visually the right side bearing has moved out slightly but nothing like it was.
I now have a slightly different issue that existed before I stripped down the bike - some light binding. The rear brake linings have a very slight bind.  I had to file the brake shoe ends where they pivot as there was no room for the top washer only the split pin. The brake shoes also appear to be a tad wider than what feels right when you fit the brake hub it's a difficult wiggle.
There is no free play in the brake shoe system. A very slight amount of lever movement in either direction applys the brakes. It's diffucult to pin down but it feels as if the binding is more like the side of the brake linings touching the inside of the hub.
From previous posts it appears that the original brake linings are no longer available so it's a bit of a raffle to get the correct ones. My next move is to see if a chamfer on the inside edge of the curved shoe might improve things. I think but am not sure that the hub has had a new steel lining fitted in the past.
I'm going to remove the brake shoes and re-fit the hub to be 100% sure it's just the linings causing the bind.
« Last Edit: May 06, 2024, 08:09:47 PM by McCabe-Thiele (Ted) »
« Reply #5 on: May 06, 2024, 08:55:49 PM »
Ted i think that was one of 3 i had relined by Paul in Huddersfield when he was doing them.
As far as i know he used cast iron pipe not brake drums and did do them to smallest size.
It was a long time ago so maybe a bit of corrosion, i would use a flap wheel in a drill to clean out the drum.
« Reply #6 on: May 06, 2024, 09:23:30 PM »
Thanks Bryan - a few minutes ago I took out the brake hub- removed the shoes - put it back into the wheel - torqued it up rotated freely - so it's just a very close fit - as it was when I first rode the bike.
The Shoes look like the DS ones they are marked SOK 283 .
Bryan I have never had a flap wheel so how are they sized can you post or PM me a link as to the size & grade I need please?
I assume they will fit a normal drill.
« Reply #7 on: May 06, 2024, 09:44:08 PM »
Go to ebay and search flap wheel, i would use a 2 inch 60 grit to clean the drum, having seen them you may get them localy to you, b&q do them
« Reply #8 on: May 06, 2024, 10:03:45 PM »
Thanks Bryan.
Offline Moorey
« Reply #9 on: May 07, 2024, 10:27:37 AM »
Screwfix certainly do flap wheels
« Reply #10 on: May 07, 2024, 10:46:07 AM »
The brake binding is not present until I tighten the axle as I increase the tightness the binding starts.
To make sure it was not the bearings  I removed the linings re-fitted the brake hub - all free.
The only thing that really changes when it is tightened up is the inside edges of the brake shoes are closer to the inside of the wheel. There is no sign of any lip on the liner.
Where the liner meets the wheel internals it looks visually good with no sign of any lip. It might be worth doing some very slight sanding on the inside edge of the brake shoes or even a light  shamfer on the outer circumference/edge of the  lining.
I did wonder if I could mark the outer edges with some yellow road chalk and see  where it transfers to.
« Reply #11 on: May 07, 2024, 11:19:14 AM »
If it is ok with no shoes fitted and done up tight it cant be bearings or brakeplate.
It is possible that the shoes are too wide, you could put a smear of coloured grease( coppaslip comes to mind) on the edges of the shoes and see if it transfers to hub or brakeplate, i have also had shoes where they dont sit properly on the cam as they are fractionally too wide, you said you had to thin the hole end so leave springs off and see if the flat pads sit asquare on the cam.
We are at the mercy of the manufacturers and suppliers of pattern parts who dont seem to take as much care in manufacture.
When available i always use Vesrah, they seem to be a better maker
« Reply #12 on: May 07, 2024, 12:51:40 PM »
I have filed down the shoes to enable a washer to be fitted under the split pin.
On closer examination of the brake shoes alloy plate there were a couple of what looked like rub marks on the alloy shoes on the outer edges. This was just on the one shoe. I have done some very light filing of the edge  it has reduced the binding substantially when the axel is tightened up.
I am collecting a flap wheel today as well - Bryan -who sells Vesrah brake shoes in the UK?
« Reply #13 on: May 07, 2024, 01:22:03 PM »
Last ones i bought was 7 years ago Ted so cant help much
« Reply #14 on: May 07, 2024, 06:59:30 PM »
I was quite pleased with my Flap Wheel that I bought from Scewfix - trouble is it will not fit in the gap between the hub brake lining and the center of the hub - I'm sure it will come in handy in the future!
Undetered I decided to use a pair of those  dark green plastic wheels that Ken uses for polishing work. A steady five minutes with them in my Dremell,  the brake liner cleaned up really nicely. Hub fitted back in the wheel,  nipped up,  a couple of high point rub marks on the brake lining near the middle towards the edge of one brake shoe. Hub removed some sand paper on the high points, Repeated twice - all is now as it should be - wheel rotates freely at last!
I've lost count of how many times the back wheel has been removed and re-fitted over the last two days - it was worth perservering to get it right.
Thanks for the tips from those who replied to this post.
Thank goodness for my bike ramp it made it all so much easier - time for a Beer reward!
