Author Topic: Relocating or alternative to ignition switch  (Read 6920 times)
Offline DomP
« on: May 12, 2024, 03:27:15 PM »
Do any of you electrical guys know a good solution for my cafe racer build?  I'm looking to either relocate the ignition or change it to  keyless to make room for my centrally mounted gauge, any thoughts appreciated!
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Relocating or alternative to ignition switch
« Reply #1 on: May 12, 2024, 03:32:50 PM »
I've got keyless fitted to Millie, my 550 Mongrel. Graham made up the wiring and fitted a hidden master isolater switch and one of the handlebar switch gear slide switches as another isolater and the original start button starts the bike.
Offline DomP
« Reply #2 on: May 12, 2024, 03:58:35 PM »
That sounds the answer Julie, do you have any idea how he did it?
1975 XS650B
« Reply #3 on: May 12, 2024, 04:14:42 PM »
I know the very basics of how he did it but I'll ask Graham for more info later. Also, PM me over your email address and I'll send you some photos.
Offline DomP
« Reply #4 on: May 12, 2024, 09:50:35 PM »
Pm sent Julie
1975 XS650B
« Reply #5 on: May 13, 2024, 10:05:16 AM »
Pm sent Julie
Thanks Dom. I'll get back to you later, it's bike riding weather again today 😁😁😁
Offline DomP
« Reply #6 on: May 13, 2024, 05:34:04 PM »
Chatting with Roo earlier when he suggested I used the old K style frame mounted ignition, I could make up a bracket if I can't find an original but there is a wiring difference - 5 wires on my F as opposed to 4 on a K switch.  Is there a wiring solution?
1975 XS650B
« Reply #7 on: May 13, 2024, 10:24:15 PM »
Different barrel
https://www.ebay.co.uk/itm/272230431458?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=bmuel-XcT82&sssrc=4429486&ssuid=uBNVIRM1Sxq&var=&widget_ver=artemis&media=WHATS_APP
Offline DomP
« Reply #8 on: May 14, 2024, 08:16:26 AM »
Looking at the wiring diagrams I seems the 4 wire switch has two browns linked into one, I wonder if its as simple as doing that?
1975 XS650B
« Reply #9 on: May 14, 2024, 08:52:26 AM »
I’ve the Motogadget Dom as you know but  that’s what straight onto mine.
Offline DomP
« Reply #10 on: May 14, 2024, 11:16:07 AM »
Yeah Motogadget was just a step toofar financially for me, I keep thinking 'cheap build remember, cheap build'  🤣
I'm sure an electrical genius will answer my query
1975 XS650B
« Reply #11 on: May 14, 2024, 01:25:33 PM »
More than likely, cue Bryan, Ash, Ken; Oo, sorry
Isn’t there a link on the classic octane site for a slot into the loom 4 way key barrel, I’m sure there is but you may need to list the videos and go to the links on each one to see but I’m sure there’s a link, maybe a hamazon link.
Online Bryanj
« Reply #12 on: May 14, 2024, 02:02:42 PM »
What actual model is it and where is the ignition switch now?
Offline DomP
« Reply #13 on: May 14, 2024, 03:37:38 PM »
Hi Bryan, it's my cb550f1 with the hugely long centrally mounted ignition barrel which I'd like to move somewhere more discrete
1975 XS650B
Online Bryanj
« Reply #14 on: May 14, 2024, 03:58:52 PM »
If the only difference is the extra brown wire then you should be able to use the earlier 4 wire switch but good luck finding an original Honda bracket and then you would need to weld a bracket for it to bolt to onto the frame.
The us boys used to move the early switch to between the clocks with a bracket that i may have one of somewhere but finding it is a problem.
I am just back from my sisters funeral, give me some time and i will check out the wiring diagrams for you
