Author Topic: Mike's CB550 Project  (Read 170715 times)
Re: Mike's CB550 Project
« Reply #105 on: October 18, 2024, 06:54:52 PM »
Those are perfect mate
Offline Mike_Berkshire
« Reply #106 on: October 18, 2024, 07:52:11 PM »
Thanks Bryan! I’m dead chuffed that I managed to do this :-)
« Reply #107 on: October 21, 2024, 08:29:55 AM »
All in all and thanks to all the advice and guidance from the forum; good progress this weekend. The engine is now back together, valve timing done and inlet tappets set. The exhaust tappets will be set shortly when the feeler gauges arrive which will allow me to measure the right gap. My current gauges gave me the choice of 0.05mm and 0.1mm with nothing in between. I also had a nice surprise in that I had a proper look at the tank and the seat for the first time since I had stripped the bike down. The seat pan has very little corrosion, just some pitting coming through the paint in places and the tank has just one dent; I thought it had 2 for some reason.
Exhaust system coming this week (4 into 1 Stainless Delkevic) and once that is on the next mountain to scale is the electrics.
Mike
« Reply #108 on: October 21, 2024, 09:36:23 AM »
Looks great Mike.
« Reply #109 on: October 21, 2024, 10:33:32 AM »
Looking good Mike! Nice work done there, like the black cylinders too!
« Reply #110 on: October 21, 2024, 11:21:54 AM »
Thanks Johnny. Black cylinders, black headlamp brackets, black grabrail - much easier than chrome plating :-)
« Reply #111 on: October 21, 2024, 12:13:42 PM »
Indeed Mike, just had a quote from Chromefix for the following - £380 + VAT.
« Reply #112 on: October 21, 2024, 12:29:17 PM »
Ouch! If you zoom in you might be able to see my silver painted clock dishes too - didn't work out quite how I had pictured them in my minds eye.
« Reply #113 on: October 21, 2024, 12:39:12 PM »
Not as shiny but tidy and cheaper!
« Reply #114 on: October 21, 2024, 12:48:59 PM »
Mike
You can set the tappet clearance without feeler gauges if you know the thread pitch of the adjuster screw.
For example; pitch of 0.5mm, half a turn gives 0.25, quarter turn 0.125mm.
Bryan will be along shortly to give the right amount of rotation.
« Reply #115 on: October 21, 2024, 12:59:31 PM »
Might be cheaper to buy some of that new?
« Reply #116 on: October 21, 2024, 01:16:21 PM »
Mike
Thanks, I hadn't thought of that. The feeler gauges have just arrived though so I will use them for now.
« Reply #117 on: November 01, 2024, 11:32:49 AM »
Although I did a full rebuild on the carbs before the stripdown to get the bike running I have split them gain, replaced fuel lines and vacuum links with new tubing, removed the float bowls to check for any crap that might have got in and then reassembled the carbs and done another bench synch. Carbs are now back on the bike with new carb to engine rubber boots and Im in the process of putting the air intake/plenum etc back together - a bit of a puzzle as this was in bits when I got the bike.
I have new rubber boots from carbs to plenum; I am assuming that the 2 rubbers without the curve/bend in them are for carbs 2 and 3 and that the ones with the bend in them are for carbs 1 and 4 and they are orientated in the plenum so that the intake venturi bit of the boot faces towards where the air flows in, ie towards the airbox itself. Is that right?
Cheers, Mike
« Reply #118 on: November 01, 2024, 11:58:12 AM »
Like this Mike?
« Reply #119 on: November 01, 2024, 03:06:22 PM »
Yes, thanks. It is the portion that is inside the plenum I am trying to work out as 2 of the boots are concentric and 2 of them have an angled portion that sits in the plenum. I am assuming that the one in your picture (carb #1) is angled on the inside of the plenum, away from the choke lever and towards the paper element?
