Author Topic: Koso gauge RPM set up  (Read 23267 times)
Offline DomP
Re: Koso gauge RPM set up
« Reply #30 on: September 26, 2024, 08:04:32 PM »
Thanks,  I hope it works finally as I've spent far to much time trying to get it working.  Koso's instructions are absolutely laughable.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline DomP
« Reply #31 on: September 28, 2024, 07:33:07 PM »
It works!!!  Thanks everyone for all your help, that's another hurdle overcome.
1975 XS650B
« Reply #32 on: September 28, 2024, 07:53:48 PM »
So how did you connect the wiring to make it work?
Might be worth posting the connections/colours you finally used to get it working for the benefit of others here.
« Reply #33 on: September 28, 2024, 09:10:17 PM »
Well done and nice to get another piece of a jigsaw in place.
Offline DomP
« Reply #34 on: September 28, 2024, 09:17:14 PM »
It is, now really just the carbs to get fine tuned, I did a quick float level test with clear aquarium airline and even though I set the floats using Julie's method I've got some running too low and at least one borderline too high.  Carbs off again unless I fiddle around with them in situ
1975 XS650B
« Reply #35 on: September 28, 2024, 09:22:11 PM »
Yes, it would be useful info in thread if anyone else then searches for the same .
It should be any one of the yellow wires from alternator windings toward the rectifier Ted. Any of the three would give a "pulse count" to the tachometer if it's equipped to take that input.
I was working with someone on a car and didn't initially realise they did this. It had various input to ecu from electronic ignition etc but with tacho traced back to alternator. Thatt had a winding "tapping" on back of case that came from prior to rectified output post.
Peculiarly, he'd changed the pulley diameter on the alternator such that the rpm was showing different to crank speed  ;D which won't happen on these Honda engines with winding etc  being directly on crankshaft.
That had dome industrial head scratching going on  ;D
Offline DomP
« Reply #36 on: September 28, 2024, 10:56:14 PM »
I'm amazed Koso didn't suggest this in their set up instructions and that it has taken over ten emails to them to get this sorted, it really was as simple as running a wire from the rpm signal wire to any one of the three yellow wires coming from the alternator.  I didn't get an accurate reading straight away but that is adjusted in the gauge menu depending on how many signals you are getting per rotation.
 Instead Koso suggest either wrapping the signal wire ten times around a plug ht lead or connecting to either the blue or yellow wires coming from the points, or in my case Dyna S ignition, the wrap method gave no read whatsoever where as the ignition method gave me a fixed 1000rpm at any rev range.
« Last Edit: September 28, 2024, 10:59:13 PM by DomP »
1975 XS650B
