Author Topic: Fork Oil Weight?  (Read 7001 times)
Offline Mikep328
Re: Fork Oil Weight?
« Reply #15 on: June 09, 2024, 01:59:11 PM »
"Slacken the pinch bolt in the top yoke first."
Thanks, Gareth!!!!!!!
After loosening the pinch bolts, the fork bolts barely took a nudge to remove!!  :) :)
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Mikep328
« Reply #16 on: June 17, 2024, 12:58:48 PM »
Changed the fork oil today.  The old oil was very dark but since I don't know what brand was in there, maybe that was the normal color!  It definitely was not ATF.    I used a 60ml syringe/short piece of tubing to add the new oil which made it quite easy.   In order to reinstall the fork bolt on the right side, I had to loosen the handlebars/rotate them a bit to allow a socket/extension to fit on the bolt.  With the box end ratchet wrench I used to remove the bolts, I couldn't generate enough finger pressure to push the bolt into the threads against the spring.  Pushing down with the ratchet/extension/socket, I was able to compress the spring sufficiently to allow the bolt to screw in.
The forks had been working well enough so I wondered if I was wasting my time chasing the fluid but the Castrol 10W fork oil made the forks much smoother in operation so I'm happy I did it! :)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #17 on: June 17, 2024, 01:35:33 PM »
My old fork oil was very dark on my 400 probably oil & seal degridation over time  - more alarmingly one side was extremely low - so I could feel the differance straight away.
