Author Topic: Gear Lever Linkage Rose Joint possible alternative CB250RSA also 400/4 etc  (Read 5534 times)
  • Moderator
My 1980 CB250 RSA gear change linkage 'rose' joints were completely fooked and I am restoring this bike on a budget (albeit one which already totals to probably considerably more than it's worth ..but hey ho.  ::)
Anyway I bought the parts below ... the cheapo rose joints were far to big so I chopped them to the correct length and trimmed down the diameter and profile of the round bit to be the same size as the Honda originals. I still need to tidy up the profile a bit  and also zinc plate them ... I am thinking of two thin O-rings and a bolt and nut through the eyelet to seal the joint before plating. This is deffo one for home plating as I don't know of any commercial platers, who would entertain doing it.
The replacement boots look fairly decent and didn't tear on my test-out assembly, to ascertain if they are rubbish or not. Obviously, I will have to use a fixing for the normally peened over pin used on the lever parts but that's no big deal.
Joint before modification.
Joint after modification and replacement rubber boot.
Test assembled with Rubber boot
CB250RSA Boot Kit
Rose Joints on Ebay (L&R hand thread m6)
« Last Edit: June 04, 2024, 11:27:42 PM by AshimotoK0 »
  • Moderator
Honda CB250RSA original gear lever linkage setup (1980 model)
Good to see some progress Ash.
How many miles were on that gear lever assembly as a matter of interest?
  • Moderator
50k
That's pretty good milage really for that joint.
Offline Athame57
I got 77,000 miles out of one of my CB250 RS's , never had any trouble with the gear linkage.  ;D It was split kick start joints that I had a lot of trouble with.  ::)
1978 CB400F2 named Elen.
  • Moderator
Were you a courier? Lot of miles that.
A lot of love for the RSA ... seem to be gaining popularity recently ... maybe it's 'cos I got one  ;D ;D
