Author Topic: CB550F1 fuel tap  (Read 4760 times)
Offline DomP
CB550F1 fuel tap
« on: June 05, 2024, 07:05:17 PM »
I'm looking for the above if anyone has one available
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: CB550F1 fuel tap
« Reply #1 on: June 05, 2024, 07:40:38 PM »
Cant remember what type that is, do you have a pic
Offline DomP
« Reply #2 on: June 05, 2024, 08:08:37 PM »
It should be a twin outlet but the one on it is a single with the hoses tee'd together, the other end is a 21mm nut to male threaded tank union.  Does that help Bryan?
1975 XS650B
« Reply #3 on: June 05, 2024, 08:37:04 PM »
Possibly, i had one or two for a 550cbx but cheap pattern ones, will have to see if i can find it/them
Offline DomP
« Reply #4 on: June 05, 2024, 08:57:19 PM »
Yeah that's what mine is Bryan, really dodgy looking thing.  Does it matter whether I use a twin or single outlet?
1975 XS650B
Offline mickwinf
« Reply #5 on: June 05, 2024, 11:11:06 PM »
My f2 had a single outlet with a y joining piece.
« Reply #6 on: June 05, 2024, 11:18:15 PM »
if youve only got a single outlet Dom I can send you a brass T so you can convert from single to twin as the 550F2 has I have several in the shed that will fit and they're barnd new mate.
« Reply #7 on: June 05, 2024, 11:21:49 PM »
Like this Dom, ………..
« Reply #8 on: June 06, 2024, 01:11:45 AM »
As said its fine to use either
Offline davidcumbria
« Reply #10 on: June 06, 2024, 06:50:32 PM »
That’s a fair solution Dave, presumably the rubbers are still intact then?
That’d do yer Dom, at least you’ve some working feedback from Dave that it’s a good unit…..
Offline DomP
« Reply #11 on: June 06, 2024, 08:32:47 PM »
Thanks Dave looks like a good option, I've read somewhere, possibly on here, not to use an inline filter but it seems like a sensible thing to do for added cleanliness of fuel.  What's the popular opinion?
1975 XS650B
« Reply #12 on: June 06, 2024, 09:14:29 PM »
I have one on all of ours except the VFR. It only takes a speck of crap and your day’s ruined, I use the flat ones that have a magnet in them on the inlet side and they seem to work great. That being said Multiman (Tim) bought some and they melted as soon as fuel went through them so only get from the decent sellers, etc, yer know.
I only fitted these as they were the smallest I could find that fitted the gap I wanted them in but I’ve had no faults at all.
Excuse picture I had to lean over 2 bikes and dangle upside down as the 550 is against the wall and o knew that one’s not rigged up to the tank yet so was visible for a piccie.
I pay about £4.50, Tim paid a bit less and his were green so
stay away from the green ones!
Offline DomP
« Reply #13 on: June 06, 2024, 09:18:17 PM »
Thanks Roo, perfect! There's a lovely photo of your fuel filter about 5 posts above your last one🤪
« Last Edit: June 06, 2024, 09:32:10 PM by DomP »
1975 XS650B
« Reply #14 on: June 06, 2024, 10:02:57 PM »
I only used the tap not the pipe or filter but so far (4 months) tap seems to be working fine, turning smoothly with no leaks.
