Author Topic: Fuel tap gubbins CB550F2  (Read 1897 times)
« on: June 07, 2024, 11:32:09 PM »
Evening all, it appears I have lost the small rubber washer as shown in the piccy, has anybody got a spare or know where I might be able to find one?
Big ask I know!
It sits under that gauze on top of the tap……..
Re: Fuel tap gubbins CB550F2
« Reply #1 on: June 08, 2024, 12:01:54 AM »
Do I specifically need one, that shape or can I get away with a flat rubber washer in its place? The Honda one has cut outs, is it something to do with this slot?
Excuse or if in there, was fiddling with what I had and didn’t take it out first the pic.
« Reply #2 on: June 08, 2024, 10:32:21 AM »
If it's a thick o-ring Roo can you use two thinner o-rings together to give the correct inner and outer diameter? I'm only suggesting this because you can no longer get the o-ring for the 400/4 fuel tap (this is the o-ring that fits behind the front plate of the tap and not the one on the fuel delivery tube as you need). DSS sells a replacement kit that consists of two rings placed together, it does work. Maybe try a similar approach?
1976 Honda 400/4
« Reply #3 on: June 08, 2024, 10:38:53 AM »
Nice one Dave, so am I completely covering the base of the pipe to cover all of the aperture and that smiley face you can see?
Excuse triping errors, I only read it again this morning and realised it must have been very late
« Reply #4 on: June 08, 2024, 03:51:36 PM »
DO NOT cover the smiley face, that is your reserve outlet mate
« Reply #5 on: June 08, 2024, 04:16:13 PM »
Never even come across the opportunity to look into one until now Bryan, that’s just the info I was after, at least I can fashion something up. My strainer tube is brand new it’s just there was a small slit in the bag so no washer. I could get another as mentioned, from DSS but I’m not paying 30 odd quid for a rubber washer. Really helpful, cheers mate
