Author Topic: 400/4 air intake assembley  (Read 3522 times)
Offline ianmck
« on: June 10, 2024, 08:11:06 PM »
I am having a lot of trouble reconnecting the air filter to air box assembly, is there a simple way or procedure to refit it all together.
any advice would be much appreciated.
thank you in advance.
1977 400/4 supersport.   1973 cb750 K4,
Offline Alexrayz
  • 1976 CB400F- Just making my way through the galaxy
Re: 400/4 air intake assembley
« Reply #1 on: June 10, 2024, 08:20:08 PM »
Do you mean you have trouble reconnecting the airbox itself or do you mean something else? Pics help if you have any.
Either way yeah it can be tricky but I would need more precisions to give you accurate advice.
Cheers!
If it aint broken don't fix it
Offline ianmck
« Reply #2 on: June 10, 2024, 08:55:38 PM »
it is the connection from the air filter to the air box.
hope that is more helpful.
« Reply #3 on: June 10, 2024, 09:12:32 PM »
First thing is too keep the air filter box itself loose to give you some 'jiggle' room. Just loosen off the fixing bolts.
The main issue is feeding the large metal trumpet into the rubber sleeve on the plenum chamber. I spray both the metal tube and the rubber with WD40 to provide a bit of lubricant to both surfaces and this helps. It is still difficult though but wriggle the metal tube as you feed it into the rubber sleeve and it will go in. Make sure you have the large metal oval fixing band in place over the rubber sleeve BEFORE you insert the metal tube, it is very difficult to insert the metal band afterwards.
Once everything is in tighten up the air filter housing fixing bolts followed by the screw on the metal band.
Offline Alexrayz
« Reply #4 on: June 10, 2024, 09:18:54 PM »
Okay yup I see it. What Dave said. Also once the trumpet is fully in you can help the lip of the rubber gasket by pushing it from the inside of the trumpet. Either you can use your hand if it’s not too big or using something long and not sharp. That’s what I usually do and it does make it a lot easier.
Offline ianmck
« Reply #5 on: June 11, 2024, 08:47:35 PM »
Sorted ,got the wiggle room, did the lube ,forgot to fit he metal band, but managed to wangle it into place.
Thanks for the advice, much appreciated.
hope I never have to do it again anytime soon.
