Author Topic: carb measuring  (Read 3639 times)
Offline RGP750
carb measuring
« on: June 13, 2024, 05:23:59 PM »
HiAll
I'm rebuilding a 1971 cb125 twin and it should have 18 carbs (not literally) I have got my 20 carbs mixed up with them.
I believe the 18 and 20 is the choke size in MM .
where should I be measuring? is it the width through the inlet?
Cheers Rich
1972 500/4
1973 CB175
1972 CB175
1959 BSA Super rocket
1927 960cc Matchless 'v' twin
1969 750 K0
Re: carb measuring
« Reply #1 on: June 13, 2024, 05:35:00 PM »
Normally it's the height,
On the CB200 the venturi is narrow, but the full height,
On the 500,the venturi seems circular,
Hope this helps
Offline RGP750
Re: carb measuring
« Reply #2 on: June 13, 2024, 06:32:43 PM »
Thanks John I'll take a look at that.
1972 500/4
1973 CB175
1972 CB175
1969 750 K0
