Author Topic: Re-plating crankcase bolts  (Read 3734 times)
Offline Fleabie
« on: June 18, 2024, 02:58:32 PM »
Hi, I am getting ready to replate my crankcase bolts in zinc using a Gateros kit. The instructions say that if you have high tensile bolts, you need to use a slightly different cleaning process to avoid "hydrogen embrittlement".
Does anyone know if the original crankcase bolts are high tensile ? I have searched high and low for a definitive answer but I haven't found one yet.
For the 10 bolts that are torqued down and secure the crank in the crankcase, 4 of them are unmarked and the other 6 longer ones (see picture) are marked with what looks like a '9' (or maybe a backwards 'P' or maybe even a lower case 'b'!)
Bill.
Re: Re-plating crankcase bolts
« Reply #1 on: June 18, 2024, 03:22:43 PM »
It's a 9. But I'm not sure that's the tensile strength or not as I thought they were 8.8's, which is almost 9 I suppose🤔🤔🤔. We've always had ours re zinc plated, after us cleaning them and never had any issues.
« Last Edit: June 18, 2024, 03:26:00 PM by Nurse Julie »
« Reply #2 on: June 18, 2024, 05:22:54 PM »
I always strip high-tensile bolts and spokes with my Witches Brew described on this forum. Its alkaline based and much more gentle than Hydrochloric acid. I will try to get link.
« Last Edit: June 18, 2024, 06:43:33 PM by AshimotoK0 »
Offline Fleabie
« Reply #4 on: June 18, 2024, 07:46:03 PM »
Thanks to you both for the replies.
Ash: Do you just use your witches brew for stripping every type of metal, be it high tensile or other? I.e. play it safe and just use your brew?
Also, Do you know if the crankcase bolts are high tensile?
« Reply #5 on: June 18, 2024, 08:20:12 PM »
I do not know the definitive answer but my thought  process is that the ten bolts are essential crank main bearing bolts as opposed to the remaining crank case bolts that just secure the casing halves. Grade 8.8 is high tensile
Generally speaking crank case bolts would be high tensile.
« Reply #6 on: June 18, 2024, 09:16:25 PM »
I mainly use it for spokes. I agree with Julie ..normal acid stripping OK for no9 crankcase bolts.
Offline Fleabie
« Reply #7 on: June 19, 2024, 07:29:42 AM »
Thanks all. Much appreciated as usual 🙂
