Author Topic: Stripped bowl threads on carbs Helicoil guidance needed.  (Read 10852 times)
Offline robvangulik
  • Honda Fourever
Re: Stripped bowl threads on carbs Helicoil guidance needed.
« Reply #15 on: July 08, 2024, 11:53:31 PM »
I Helicoiled all my floatbowl threads 2 weeks ago, because three had gone bad loosening the bowls.
I ordered a set from Amazon, cost me 7 euro INCLUDING postage, took 3 days to get here and then spent less than an hour on a rainy sunday afternoon to put them in. The set was complete with all the tools I needed, drill, allen key, thread turner inner ;) and 24 coils, so enough spare to make mistakes (which I didn't).
Offline Scooter
« Reply #16 on: July 23, 2024, 09:55:03 PM »
I have used a helicoil kit for 8-32 screws, repairing 7 of the 12 screw holes on my 77 550k. Also repaired a couple of holes on the S&S superleaker (Super E) on my harley. The kit had everything execpt the required drill bit to ready the hole for tapping.  I believe it was an 11/64 inch drill required (apologies to metric folks). Only problem i had was breaking the tang in blind holes. Repairs seem to be holding.
1977 Honda CB550k3
1998 Road King
1965 Ford Mustang
« Reply #17 on: July 24, 2024, 12:45:17 AM »
I have ended up cutting the tip off my existing Helicoil Tap with my Dremil type tool so it's now flat ended - it still has the tapered lead at the end so should be fine. I bought an M5 kit a while ago that came with plenty of coils.
I'm planning on doing a practice thread first on some scrap alloy that my brother has when I see him on Friday.
« Reply #18 on: July 25, 2024, 12:56:10 PM »
Ted, I replaced about half of the threads on my spare 400/4 carbs with helicoils. I use Loctite 648 when inserting then trim off any helicoil AFTER it has cured with the ol' dremel.
Okay Matt, I have tapped out the two dodgy carb bowl threads so next I need to fit the coil inserts.
It was harder than I imagined to keep the Tap at 90 deg to the carb body - I now have some new  threads.
I like the idea of giving the coil insert some extra intergrity using Loctite or similar.
With the Loctite 648 - is there any danger that the Loctite will seep through the coils and cause an issue?
Offline Matt_Harrington
« Reply #19 on: July 25, 2024, 02:37:42 PM »
Ted, I don't think so. I would just let the Loctite cure.....
« Reply #20 on: July 26, 2024, 09:55:07 PM »
I did wonder if J-B original cold weld (2 part) would work as an alternative as I have some left over from a previous repair job?
Online Bryanj
« Reply #21 on: July 27, 2024, 07:56:30 AM »
That should be ok Ted, same as araldite i think, clean well with something like brake cleaner first and let it dry
« Reply #22 on: July 28, 2024, 11:51:56 AM »
I ordered some of the Loctite 648 that was due for delivery yesterday Bryan but getting impatient so thought about the J-B as an alternative.
After more research I'm going to wait for the Loctite 648 - I've been away from the 500 for a month so another few days will not hurt.
« Reply #23 on: July 31, 2024, 11:32:32 AM »
After my short summer recess I have finally fitted Helicoils to the two stripped carb bowl threads.
My first Helicoil  was okay but I did not manage to get the thread as far down as I should have with the tap so the tang came off as I tried to wind it down the last bit. I have used a slightly shorter screw, Result!
Before I fitted the second Helicoil I ground off a tad more of my reamer with my Dremel. I managed an extra  thread right to the end.
The Helicoil fits beautifully - so practice makes perfect proved yet again.
It's my first ever Helicoil so I am chuffed to bits & re-motivated to press on with the carb cleaning/re-fitting.
Just wondered if I ought to fit a new set of 40 jets or is there enough control with the air screws to cope with any enlargements caused by previous cleaning etc?
Comments welcome regarding jet replacement thoughts.
« Last Edit: July 31, 2024, 11:39:53 AM by McCabe-Thiele (Ted) »
