Author Topic: Spacers  (Read 2709 times)
Online deltarider
Spacers
« on: June 22, 2024, 03:03:40 PM »
In the parts box I came across two spacers (clutch) I've bought decades ago, for... just in case. I guess Honda has fitted these on assembly when a clutch showed a degree of play and none when there was no play at all. My own bike came with none and still does not need one. Am I right to assume it has little to do with wear? The smaller one is 0.5mm thick and the larger one 0.1mm. Why the outside diameters are different? No idea. :? By the way, the spacers are mentioned in all CB500/550 parts lists as optional parts either with ( ) or with an 'N'.
Re: Spacers
« Reply #1 on: June 22, 2024, 03:25:07 PM »
I think Oddjob had some made a while ago and he sent me a couple FOC
Re: Spacers
« Reply #2 on: June 22, 2024, 04:34:38 PM »
You can still message Ken on here but leave your phone number, he can’t message back. Think he’s got some sets left.
Re: Spacers
« Reply #3 on: June 22, 2024, 04:43:09 PM »
Yes they were optional to take out engineering tolerances, common to find non fitted
Online deltarider
Re: Spacers
« Reply #4 on: June 22, 2024, 06:18:58 PM »
A member in the German forum worried after he had turned two CB550s into one and had three of these left over. I still don't understand why my 0,1mm spacer is bigger than the 0,5mm one. Were they meant to go in different spots?
