Author Topic: Carb links  (Read 8078 times)
Offline DomP
Carb links
« on: July 08, 2024, 08:35:58 PM »
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: Carb links
« Reply #1 on: July 08, 2024, 09:52:41 PM »
I might have two but not home until Thursday so can’t look at the min Dom. Have you a diagnosis or just noticed something else that needs fettling?
Re: Carb links
« Reply #2 on: July 08, 2024, 10:38:50 PM »
I think Nurse Julie may sell these as well.
At least being new they are flat, old ones tend to be buckled and when you try and straighten them they have a habit of splitting!
Offline DomP
Re: Carb links
« Reply #3 on: July 08, 2024, 10:40:30 PM »
Cheers Roo!  just one is a bit mangled and the other snapped through mate, it makes tightening up the nuts a bit tricky on that pair of carbs.  I haven't looked at it since I came across the dodgy plugs, I googled it and they appear legit but fakes may be pretty good maybe?
1975 XS650B
Re: Carb links
« Reply #4 on: July 08, 2024, 10:48:03 PM »
I think it’s something to do with the writing around the plug just under the nut bit.  Whether it’s there or not or summing.
If you can hang on I’ll find em and ship em up to you bud.
Re: Carb links
« Reply #5 on: July 08, 2024, 11:13:09 PM »
Not that expensive when you consider Honda only sell them with the adjuster assembly and if available cost 100's
Offline DomP
Re: Carb links
« Reply #6 on: July 09, 2024, 10:36:16 AM »
Thanks Roo mate, and yes true Bryan!
1975 XS650B
Re: Carb links
« Reply #7 on: July 09, 2024, 10:37:56 AM »
I think if it’s there and nice and tidy it’s legit, if not is an immo job. Like I say, summing like that
Offline DomP
Re: Carb links
« Reply #8 on: July 09, 2024, 07:58:34 PM »
New plugs arrived Roo, look identical which begs the questin why are two of mine now fubar'd?
1975 XS650B
Re: Carb links
« Reply #9 on: July 09, 2024, 10:17:55 PM »
Forgot to send it……..
https://youtube.com/shorts/B7zQ1_rvhik?si=fqBIZqAib2gjM6Di
Not sure how accurate it is but a good benchmark test when buying I guess.
It’s certainly an interesting one mate!
Re: Carb links
« Reply #10 on: July 10, 2024, 06:36:01 AM »
Interesting video Roo, haven’t seen that one.
Offline DomP
Re: Carb links
« Reply #11 on: July 11, 2024, 06:30:42 PM »
I really can't believe I'm having such bad luck, four new plugs arrived so I thought let's test them before fitting.  One has no continuity right out of the box!
*well it still sparks even though my multimeter showed there to be no continuity from the electrode to the cap end?
« Last Edit: July 11, 2024, 06:47:53 PM by DomP »
1975 XS650B
