Pistons
Topic: Pistons (Read 4700 times)
Murf
SOHC Expert
Pistons
July 14, 2024, 10:58:32 AM »
Hi
I am rebuilding the top end of a 550K1, the engine bore is standard and good, the pistons are good size wise. However somebody has been in the engine before me and cleaned the piston tops either with a belt sander or a wire brush on a grinder so there are marks all across the tops. They are not too deep and I could polish them out, but would lose a tiny amount of height and therefore compression. Just wondering what options are on that. I am going to hone the bores and put new rings on the pistons or put in new pistons and rings if needed.
Can the later F pistons with the raised crowns to increase compression 9.1:1 be used in the K1 engine. I am putting in a slightly hotter cam. Cam was knackered so have had to have it repaired and reground with a better profile. Thanks for any opinions or help.
Nurse Julie
Re: Pistons
July 14, 2024, 11:17:37 AM »
550F and 550K use exactly the same pistons and rings. It's the 750/4 that are different, the F model had the domed pistons, the K's didn't.
Re: Pistons
July 14, 2024, 05:32:28 PM »
As Julie says all the 550 pistons are the same, somewhere i have a set of Yoshimura +0,5mm piston kits but they aint cheap and neither is the rebore
Murf
SOHC Expert
Re: Pistons
July 16, 2024, 01:03:33 AM »
Yoshimura pistons
Great pistons but unfortunately a bit overkill for what I am doing but thanks.
I checked all the ring end gaps today and they are all in the region of 0.025 thou so out of spec but still within the max tolerance which I believe is 0.027’’ The top of one piston has quite bad damage so am thinking of getting new standard pistons and rings so thinking of trying the IMD ones. The thing I am worried about with the later F pistons is if the valves on the K engine are likely to hit the domed piston, I will have a check to see if there is any info about this.
Hi Julie I do need a couple of parts you have on your eBay site, cam chain, oil pump O rings and carb seals. How do I get the 10% off thanks.
Re: Pistons
July 16, 2024, 01:47:01 AM »
There are no domed pistons in the 500 or 550 range, the ONLY domed pistons are 750
Nurse Julie
Re: Pistons
July 16, 2024, 08:16:35 AM »
Hi Murf.
Just send me a PM about any parts you need.
Many thanks
K2-K6
Re: Pistons
July 16, 2024, 09:12:44 AM »
Obviously no options with std piston to change compression specifications.
It is though a consideration, in that a camshaft with extended overlap /duration will lower the effective compression ratio, all things being equal.
The geometric ratio of combustion chamber volume to swept volume remains the same, but with valve opening moved then the active ratio will usually be reduced (assuming longer opening etc) which will reduce the torque at lower rpm.
The changes effectively push the torque peak upward to occur a raised rpm point but looses combustion effectiveness at the lower speeds.
It gives something of a " false" gain, in that the brake horse power is a calculation involving rpm as a factor in projecting work rate.
Net effect is that you have to rev it to get to torque peak by using lowered gearing, seems more dramatic peak as the reduced torque in low rpm range has greater contrast to the high rev performance.
Itll be faster by the effect of fitting in more power stroke to a measured distance that before (lower gearing, higher revs) but at the same low range rpm it will be correspondingly slower from less real torque. In other words, you've always got to ride it at revs to see an increase in power.
Lifting the static compression ratio is a way of compensation to avoid some of this.
You'd probably need a dry build though to assess piston clearance to head and that to valves at the cam duration specification used.
Murf
SOHC Expert
Re: Pistons
July 17, 2024, 11:15:49 AM »
Hi
Thanks for the info re F model pistons, I have ordered some pistons from IMD and as you say only flat top pistons for the 550. It has cost around £100 more than just getting new rings for the old pistons, size wise the original pistons were ok but the crowns were just so scored by the crazed wire brusher that got in the engine before me. The rings were getting close to the max gap. The standard bore is amazingly good though with virtually no wear. I spoke to IMD and they were very helpful. I know I am taking a risk putting new pistons in an old bore, have to hope that IMD pistons are accurate with there sizes. I will measure them when they come and pray. I have honed the bore to deglaze it.
I tend to agree with what is said about camshafts and an improved cam not being much good without other engine mods and I definitely don’t want an engine that is really cammy. The thing is that my camshaft was knackered, I looked around at used cams and came the conclusion that they were all just as knackered or worse than the one I had. I decided to try the option of getting my cam repaired and reground and went for a slightly different profile. Will it be good or not, I don’t know but thought it was worth a try. If it’s not great then I will get another used cam, get it repaired and have it reground standard. I got the info about Newman Cams from the forum so thanks, they are very helpful on the phone. I will give info on them when I get the cam back.
Re: Pistons
July 17, 2024, 01:26:50 PM »
IMD are very accurate with their sizing, i hve had several sets from them, honing, whilst the necessary thing, does remove metal and can put the bore out of spec, it depends on the type of hone used the nicrohone or dingleball is the best for this job
Pistons
