Author Topic: Crank bearings good or bad  (Read 28783 times)
Offline Acro1985
Re: Crank bearings good or bad
« Reply #75 on: September 02, 2024, 06:35:37 AM »
Are the brown main shells thicker than the greens, apologies I am still struggling to understand the difference thickness of them all.
Ted - you might have been on to something about the grease, I did them again yesterday without grease and on the original shells got 0.038mm this time and the new green shells I got to try was in between  0.038 and 0.050mm. having said that I am still not convinced its not me buggering it up, but its a learning curve.
On a positive note the big end shells where all bang on 0.038mm so I don't need to replace them.
« Reply #76 on: September 02, 2024, 07:40:20 AM »
Black
Brown
Green
Yellow
Red
Abpve are the Honda shell colours in descending order of thickness, not all colours are used on all models.
Black is the thickest.
« Last Edit: September 02, 2024, 05:43:03 PM by McCabe-Thiele (Ted) »
Offline Acro1985
« Reply #77 on: September 02, 2024, 12:26:41 PM »
Cheers Ted I will give a set of Brown ago
