Author Topic: Wiring harness connection to battery tray (with pics)  (Read 12824 times)
Offline Mike_Berkshire
Re: Wiring harness connection to battery tray (with pics)
« Reply #15 on: August 14, 2024, 11:26:53 AM »
Thanks. So far the best price I can find is £70.00 plus postage. I will keep looking.
« Reply #16 on: August 14, 2024, 05:51:14 PM »
I have a copy but is hidden in the loft under two weddings worth of stuff.
Happy to dig it out and copy a few pages. Unless anyone else on here has easier-to-access copy?
Mark has these books published in (very) small batches. Hence the price.
Have you asked him?
Steve
« Reply #17 on: August 14, 2024, 06:26:06 PM »
Thanks Steve - I just realised I have confused things. I have a '76 550 K2, not a 750. Although maybe I still need to do something similar?
Apologies for the confusion Alan.
M
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #18 on: August 14, 2024, 07:01:43 PM »
No problem, the CB750 (K3,K4,K5) & CB550 (K0,K1) share the same 5-wire safety switch...the CB550 (K2,K3) have the 2-wire safety switch
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
« Reply #19 on: August 14, 2024, 07:41:06 PM »
Mark has been in the process of doing a 500/550 book for a few years now, hopefully available in the near future
« Reply #20 on: August 14, 2024, 09:58:00 PM »
Thanks Alan, is the safety switch the red rotary switch on the right handlebar?
« Reply #21 on: August 14, 2024, 10:13:17 PM »
Kojaycat do the block connectors.
Brilliant, I'm assuming it's the 3.9mm Japanese bullets?
https://kojaycat.co.uk/epages/950000457.sf/en_GB/?ObjectPath=/Shops/950000457/Categories/Connectors_Bullet/39mm_Japanese_Bullet_Connectors
My 400 has 3.5 mm Japanese Bullets I think my 500 is the same - I have no idea about the 750 ones.
« Reply #22 on: August 14, 2024, 11:15:47 PM »
No the red switch cuts power to the coils, the safety circuit stops the starter working
« Reply #23 on: August 15, 2024, 08:50:26 AM »
Just for clarity,......stops the starter working....when side stand is down or bike is in gear ( I assume it's the same on this bike as on mine).
« Reply #24 on: August 15, 2024, 10:48:27 AM »
I don't think the the CB750 (K3,K4,K5) & CB550 (K0.K1) had a side stand switch? They do both have the 6-way red connector fitted within the harness for the 5 -wire safety switch...just for reference the plug-in safety switch part No. is 31800-341-701...possibly not available, but it can be by-passed.
Current bikes:-
« Reply #25 on: August 15, 2024, 11:11:05 AM »
No side stand switch on mine and no red connector block either - all connector blocks are white. I guess the PO replaced the red connector block with a stock white one for some reason. There is a 5 way connector with wires going to the heat sink thing that is mounted above the starter solenoid.
Offline Yuppie_88 (Luke)
« Reply #26 on: August 15, 2024, 11:55:47 AM »
Yep, on mine (750 K4) there is no side stand switch either.
The safety unit is unfortunately discontinued - I spoke to David Silver today to confirm. This means I'll be jumping the safety unit connection as BigAl mentioned.
I've found a nice electrical box online which has 60mm centre mounts, this should bolt on directly to the original safety unit mount (could be a nice place to keep some spare fuses too). I intend to run the jumper connection through the box to keep things tidy and add a nice new connector block on the end of it. I know I'm the only one who will probably see this but, I don't like the idea of this thing flapping around ;D
« Last Edit: August 15, 2024, 01:22:14 PM by Yuppie_88 (Luke) »
« Reply #27 on: August 15, 2024, 01:45:55 PM »
This thread ought to be on the 500/550 section.
My 500 K1 has no red block connectors, no stand or clutch switch.
« Reply #28 on: August 15, 2024, 03:43:42 PM »
Good point Ted. See new post on 500/550:
« Reply #29 on: August 15, 2024, 05:25:13 PM »
I thought the site moderator could just move the whole caboodle.
