Author Topic: Painting an assembled engine.  (Read 2866 times)
Offline SteveW
« on: August 13, 2024, 01:54:57 PM »
Got my engine cleaned and ready to paint. Just one question, do you paint the bolt heads or mask them up?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Painting an assembled engine.
« Reply #1 on: August 13, 2024, 02:10:07 PM »
I painted mine before assembly - I suspect the manufacturers did not paint them as an assembled unit.
Personally I would not bother about masking up bolts you can't see so that means fewer bolts to mask if you choose that route.
I suspect if you paint the visible ones the paint will start to crack at the bolt heads, if you mask up there will still be a line so the outcome will probably end up the same.
Quicker & easier to just paint as a complete unit.
Offline Mike_Berkshire
« Reply #2 on: August 13, 2024, 09:08:44 PM »
I remember Martin6 posted about masking the bolt heads on the forum several months ago when he painted his engine.
Offline SteveW
« Reply #3 on: August 13, 2024, 11:12:38 PM »
I had a moment of inspiration and ordered a pack of different size plastic bolt caps from Amazon, save me masking up the heads.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline neat street
« Reply #4 on: August 17, 2024, 08:05:16 AM »
i use blue tac to cover the bolt heads ect, much easier and works, just pick out with a tooth pic after.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
« Reply #5 on: August 17, 2024, 07:46:11 PM »
Im going to go for the Blutack approach; thanks for the suggestion!
