Author Topic: Front Wheel/ Brake binding?  (Read 10797 times)
Offline Martin6
Re: Front Wheel/ Brake binding?
« Reply #30 on: August 21, 2024, 09:31:07 AM »
Lòoks good. I thought about a twin disc, as the threads are there on the RH fork. What did you use for the pivot arm, as they look to be handed for the LH side only?
« Reply #31 on: August 21, 2024, 09:51:10 AM »
   on the 500,the pivot is handed,but if I remember its only for the adjuster screw,when I fitted my 2nd disc I simply use a countersink drill bit to modify the arm,so the screw head would fit
Offline Martin6
« Reply #32 on: August 21, 2024, 08:31:34 PM »
Pauarc's and mine are 750s.
