Author Topic: Gear selector says, "Adios!"  (Read 5985 times)
Offline Mikep328
« on: August 16, 2024, 04:15:39 PM »
It tried to escape but it couldn't!
On my 50 mile ride today after slowing down/speeding up I went to change gears and...nothing!  My left boot hit "air;" there was no gear selector lever!   WTF?   Turned out that the circlip that holds the selector lever on shaft had abandoned its position and the lever slid out/dropped off.  Fortunately, of course, the connecter that links the lever to the gearbox shaft kept the lever from disappearing in the dust.
I slid it back into position and kept my foot pressed sideways against the lever to ensure it stayed in position for the remainder of the ride - about 15 miles.
I'd like to claim that the circlip failed due to old age but I suspect that although it might be old age related, it's not circlip old age that was the problem.  A couple of months ago I had pulled the selector lever to clean/grease the fitting.  I THOUGHT I had ensured that the circlip was correctly installed in the groove when re-assembling but when given that the two possibilities are:  1. Failure to install correctly or, 2. Steel circlip failed due to old age...well, what do you think?  ::)
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Re: Gear selector says, "Adios!"
« Reply #1 on: August 16, 2024, 05:14:23 PM »
General advice here is to not re-fit old circlips when putting the gearbox back together.
Offline Mikep328
« Reply #2 on: August 16, 2024, 06:20:10 PM »
 Sounds like good advice!!!   ;)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline Athame57
« Reply #3 on: August 16, 2024, 07:13:45 PM »
The part you seek is available here!  ;D https://www.davidsilverspares.co.uk/parts/by-part-number/partnumber_9451112000/ Dont forget the washer!
1978 CB400F2 named Elen.
Offline Green1
« Reply #4 on: August 16, 2024, 07:49:23 PM »
Could be worse. I once made the mistake of using a second hand circlip to refit my front sprocket on the Aprilia. Needless to say that was a bad move. The sprocket made a brake for it and locked the rear wheel solid.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #5 on: August 16, 2024, 08:51:55 PM »
400/4 circlips are very prone to falling off for some reason, even new circlips. A lot of us drill a small hole through the shaft and put a wire through in front of the circlip for extra peace of mind. I was going round a tight bend much too fast on Hettie, went to change down and the gear lever wasn't where it should have been, it was dragging along the tarmac...scary moment indeed  ;D ;D ;D
Offline Mikep328
« Reply #6 on: August 16, 2024, 09:34:43 PM »
Thanks NJ!  I'll drill/add wire.  I've used plenty of safety wire on my Norton Commando(s) but never realized I would need something similar on a Honda!  I would have thought Honda would have used a washer and cotter pin in that application, rather than a washer/circlip.
Old Brittbike Q/A:
Q Do I need to use safety wire?
A Only on the items you don't want to lose!
« Last Edit: August 16, 2024, 10:01:50 PM by Mikep328 »
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #7 on: August 16, 2024, 10:07:26 PM »
Could you not put wire through the ends of the circlip and twist them up?
Offline Mikep328
« Reply #8 on: August 17, 2024, 09:01:35 AM »
I thought of that but was a bit concerned that it might cause some abnormal wear because the wire would protrude a tiny bit where the washer bears against the circlip and cause the washer to not be "square" against the circlip and/or the gear lever.  Though I guess it would, at worst, just wear a groove in the washer at that point.
I might try it because I'm not comfortable using a hand drill at the bike to drill the hole in the shaft.  If the shaft was out and I could use my small drill press, I wouldn't hesitate to drill it.
Other issue is that I don't have any safety wire and I don't care to buy as spool of it for the 25mm (or less) of wire needed to do the job!  ;)
« Last Edit: August 17, 2024, 09:14:01 AM by Mikep328 »
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #9 on: August 17, 2024, 10:12:41 AM »
A blob of Silicone Sealant on the outside,
a smear of Honda bond?
« Last Edit: August 17, 2024, 10:15:33 AM by McCabe-Thiele (Ted) »
« Reply #10 on: August 17, 2024, 02:37:15 PM »
So use a small split pin
Offline Mikep328
« Reply #11 on: August 27, 2024, 04:48:54 PM »
Just to update - got the new circlip and washer from DS last week.  Installed it and tried really hard to get it to pop free, yanking/twisting/pulling/pushing the gear lever and it SEEMS firmly attached and not likely to fail.  SO I didn't make any further effort to secure it. Whether that turns out to be smart or dumb...time will tell. ;)  As I said, if I had that shaft on the bench, I'd drill it for a split pin as others have described.
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
« Reply #12 on: August 27, 2024, 08:11:18 PM »
I did wonder if SS would be better - mine is a DS clip as at the time I was not familiar with clip sizes.
Offline Mikep328
« Reply #13 on: August 28, 2024, 09:42:47 AM »
The new (DSS) circlip is much "tighter" than the original based on the amount of pressure it took to open it with the snap ring pliers.   Of course, the original might have been weakened by removal/replacement some number of times in the bike's past in addition to the one time I did it.  I was careful to only open the new one just barely enough to enable it to slide onto the shaft/snap into place when it got to the groove.  ;)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
