Author Topic: Where oh where was this extra earth strap fitted?  (Read 3827 times)
« on: August 22, 2024, 09:09:45 PM »
I have an extra earth strap left over from my 500 rebuild.
Its exactly a foot long with a 6mm battery type connector at one end, the other end is a flat 6 mm terminal the cable is 7.5 mm o/d including the insulation so pretty hefty.
I recall thinking at the time that it ws a good idea - so far no trawls of my dismantling photos have come up showing it.
I can't remember where it was fitted as an extra earth strap by a PO (Bryan or earlier) any ideas anyone?
Re: Where oh where was this extra earth strap fitted?
« Reply #1 on: August 22, 2024, 09:57:25 PM »
I have no knowledge of any extra GND wire, not separate I mean. There is a thick green wire supposed to connect to the frame where the coils are, but that is part of the harnass.
« Reply #2 on: August 23, 2024, 12:46:16 AM »
Dont remember an extra earth lead Ted, the only one i remember is battery to LH rear engine mount where paint needs to be removed.
The positive to solenoid was made up my me
« Reply #3 on: August 23, 2024, 08:58:54 PM »
I've checked the photos it was not connected directly to the battery at one end.
I'm thinking it might have been a frame to engine link or frame to rear fender.
Offline blade918
« Reply #4 on: August 25, 2024, 08:54:20 AM »
there is defo  one from battery negative  to rear engine bolt
« Reply #5 on: August 25, 2024, 09:37:58 AM »
I have that one fitted in place with powder coating removed.
I remember thinking it was a good idea at the time, just can't remember where it was fitted. I'm not going to fit it back I guess. I did wonder if it was fitted at the back between the frame somewhere and the rear mudguard to help with rear lights and indicators. I fashioned a replacement rear sub loom with good earth.
Offline neat street
« Reply #6 on: August 25, 2024, 12:43:40 PM »
starter motor??
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
« Reply #7 on: August 25, 2024, 02:00:24 PM »
Not likely plus I have a photo of the side cover off, only main starter lead before strip down & alternator wiring etc.
