Author Topic: DIY Spot-Weld Dent Puller ... a real Frankenstein/Igor contraption.  (Read 9630 times)
  • Moderator
Made this to pull lots of dents out of a CB500 Four tank.
NO this is not the 500 tank you kindly passed onto me Trigger ...I will let you have that one back.
Plan is ludicrous really. I have a beautiful Candy Jet (Jade) Green K0 paint set done by Menno a couple of years back pre-#@%$. A perfect NOS Candy Custom Gold tank with a pair of decent panels. However, I want to have a go at candy painting and the K0 came in Starlight Gold not Candy Custom Gold. So that's going to be this one is going to be. Well, that's the plan. Then all of my painting escapades will be over and I will hang up my guns for a bit.
Made from two scrap microwave transformers, timer module off eBay and one of my customers heavy duty solenoid switches (they use my automated test system in Hampshire & Lithuania and have sent me lots of samples over the years to set up the testing of their product range.)  I had to use two transformers in series connection in the end as one transformer didn't provide enough welly to geta decent weld.
Video here:-
https://www.youtube.com/shorts/mPaUYmkHL-8
« Last Edit: August 24, 2024, 08:28:08 AM by AshimotoK0 »
Re: DIY Spot-Weld Dent Puller ... a real Frankenstein/Igor contraption.
« Reply #1 on: August 24, 2024, 01:59:28 PM »
Looks usefull Ash
« Reply #2 on: August 24, 2024, 02:33:09 PM »
How do you avoid burning a hole in the tank?
  • Moderator
« Reply #3 on: August 24, 2024, 03:38:02 PM »
Short time and controlled current...never burned though yet.
« Reply #4 on: August 24, 2024, 04:20:28 PM »
I would probably put a hole straight through and out the other side!
Offline Green1
« Reply #5 on: August 24, 2024, 04:22:21 PM »
I'm crap at welding.
I like the way the welder groans at the end  ;D
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #6 on: August 24, 2024, 04:25:06 PM »
I'm as good at holding an Electric Welder steady as I am a paint brush - I know my limitations. :-[ :-[ :-[
« Reply #7 on: August 24, 2024, 10:44:05 PM »
I'm glad you know what you are doing Ash. If I tried making anything like that I'd take out the national grid!
I've seen Ed China use a similar dent pulling system on Wheeler Dealers. I think he used a bar passed through the welded 'tags' and this was connected to a hydraulic ram and the dent just pulled out!
  • Moderator
« Reply #8 on: August 25, 2024, 08:29:44 AM »
Dave .. yes I have the wavy strip and slide hammer etc but I found that it's best to put a metal block on the tank and use it as a fulcrum with a bar or screwdriver passed through the eyelet of the welded tab. You also need to apply heat to the area. Bike tanks are probably thicker than car panels and the dents are on awkward curved areas. It does seem to take a lot of force in order to 'move' the metal.
Offline neat street
« Reply #9 on: August 25, 2024, 08:48:05 AM »
well done Ash, ingenious!
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
« Reply #10 on: August 25, 2024, 09:32:17 AM »
As you will know in the car trade  there are professional dent removers who use specially made "Spoons" I think they are called to reach behind a dent, the heat up the paint area and remove some pretty big dents without damaging the paintwork. I caught my front wing on a steel post on one of my vehicles a few years ago - I was quoted over £600 to fix it. I called out a mobile dent remover who removed it. He quoted me £90 but only charged me £50 as he was not 100 % happy with the end result. I was !
Surprised no one has designed a U shaped spoon that works.
  • Moderator
« Reply #11 on: August 25, 2024, 12:38:43 PM »
Ted ..on the 500 tank the filler hole is off centre so on the side of my tank with the dents in it, it would be difficult to get anything inside, even with fancy bends. It takes a lot more force than you would think to press a deep dent out. For anyone with dents in a painted tank the guy not far from Mathewsons Auctions (think he is in Middleton N. Yorks) is magic at getting dentds out without damaging the paint. JamesH put me onto him ..not cheap though about £150 to take a dent out but much cheaper than a repaint.
« Last Edit: August 25, 2024, 12:40:36 PM by AshimotoK0 »
« Reply #12 on: August 25, 2024, 07:05:46 PM »
Utterly mental and utterly brilliant as always Ash. I love these things you get up to.
« Reply #13 on: August 26, 2024, 07:46:22 AM »
Lovely bit of work there Ash, looks a bit bonkers and ingenious at the same time. Dave I’m with you. 🤣
