Author Topic: Advice for a grease gun that works on the old honda type nipples.  (Read 1663 times)
Over the decades I somehow accumulated about three or four manual grease guns - all of them would work after a fashion.
They all had one  common characteristic in that they wasted one way or another about 75% of the grease that was loaded into them.
As the number of grease nipples on cars fell to close to zero about ten years ago I binned the lot as they would leave a wormcast of grease sometimes emptying the gun in an act of spite.
I only needed to grease the drive gates once a year so I bought a cartridge type gun that inherited the same wasteful characteristics. It came with the standard end connection that will not work on these old Honda type nipples.
No instructions came with the gun - loading the cartridge was a messy nightmare - it's never really been any good.
Looking at some previous posts for this topic I think I need a K type nipple adapter - more importantly I need a grease gun that will actually work. I've seen mention of the brand Wanner but the price range looks hefty.
Can anyone recommend a manual gun that works & a supplier of the right nipple adapter. Links would be appreciated - thanks in advance.
Does this look like a suitable adapter? https://www.ebay.co.uk/itm/165560796579
« Last Edit: August 26, 2024, 01:23:39 AM by McCabe-Thiele (Ted) »
Re: Advice for a grease gun that works on the old honda type nipples.
« Reply #1 on: August 26, 2024, 02:54:42 AM »
Ted, did i not drill and tap the long bolt to take standard 6mm thread grease nipples?
« Reply #2 on: August 26, 2024, 09:42:44 AM »
No it has the press fit type, there might have been a middle grease nipple that is the standard round profile type on the swing arm iirc.
« Last Edit: August 26, 2024, 09:54:18 AM by McCabe-Thiele (Ted) »
