Author Topic: CB550 refurb  (Read 149514 times)
Re: CB550 refurb
« Reply #60 on: October 07, 2024, 07:21:19 PM »
If it was a crack I can't envisage a catastrophic failure likely.
Re: CB550 refurb
« Reply #61 on: October 07, 2024, 09:22:34 PM »
I agree that I don’t now think it is a crack. If it was manifesting itself from the outer edge of the disc it would be plausible. Having had a good examination of the mark under magnifying glass and good light I’m quite sure it is just a scratch.
Re: CB550 refurb
« Reply #62 on: October 08, 2024, 12:22:04 AM »
That's a relief. 👍
Offline Acro1985
Re: CB550 refurb
« Reply #63 on: October 09, 2024, 12:40:52 PM »
Might be a daft question but are still able to get hold new discs or is it a case of getting hold of a second hand one that still has plenty of life left in it.
Re: CB550 refurb
« Reply #64 on: October 09, 2024, 01:32:25 PM »
Yes but look at the price!
Re: CB550 refurb
« Reply #65 on: October 09, 2024, 02:57:06 PM »
Being as how all 500 and 550 are the same shouldnot be difficult to get, oh and 500 twin
Re: CB550 refurb
« Reply #66 on: October 09, 2024, 03:02:07 PM »
Not actively pursuing but just seen this! Much better price.
Re: CB550 refurb
« Reply #67 on: October 10, 2024, 11:39:11 AM »
Another one done, with a final bit of tensioning it’ll be ready for a tyre!
Re: CB550 refurb
« Reply #68 on: October 10, 2024, 11:58:18 AM »
Do you have to grind off any excess spoke ends on the inside of the wheel or does the tape stop it lancing your inner tube?
Re: CB550 refurb
« Reply #69 on: October 10, 2024, 12:13:07 PM »
No excess spoke Ted! If they are the correct spokes for the rim they and hub they should be sound. The tape will undoubtedly cushion the seat for the inner tube, I suppose there could be small burs on the nipple ends if it had been built using a screw driver. I just use fingers and spoke spanner.
Offline Mike_Berkshire
Re: CB550 refurb
« Reply #70 on: October 10, 2024, 10:25:12 PM »
Impressive! I need at least my rear wheel rebuilt with new spokes and rim but I don’t know if I can work up the courage to do it myself; it would be a first for me.
Offline DomP
Re: CB550 refurb
« Reply #71 on: October 10, 2024, 10:46:40 PM »
It's really not that hard Mike once you've watched a few videos, the critical bit is getting CWC to send you the correct spokes, they've got mine wrong twice out of two builds.  Quite enjoyable really.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: CB550 refurb
« Reply #72 on: October 12, 2024, 08:42:05 PM »
Onward we go. Could have done this with the engine in frame but glad I removed from frame this afternoon. Definitely worthy of a top end rebuild!
Re: CB550 refurb
« Reply #73 on: October 12, 2024, 09:05:21 PM »
I've seen worse NJ's 400 strip down springs to mind - it's amazing it ran as it was when the pistons were out.
Looks like number 1 cylinder was  a tad leaner than the others - but not massively.
« Last Edit: October 12, 2024, 09:15:48 PM by McCabe-Thiele (Ted) »
Re: CB550 refurb
« Reply #74 on: October 12, 2024, 09:07:32 PM »
Average 40+yr old Honda
