Author Topic: CB550 refurb  (Read 151425 times)
Re: CB550 refurb
« Reply #75 on: October 12, 2024, 09:21:14 PM »
Meant to put this pic up too. Don’t think the end of this was located in the right place!
Re: CB550 refurb
« Reply #76 on: October 12, 2024, 10:54:34 PM »
You are correct in your assumption, probably time to change the cam chain now
Re: CB550 refurb
« Reply #77 on: October 13, 2024, 07:33:55 AM »
Probably indeed Bryan, I was hoping to avoid splitting the bottom half and haven’t had any experience with the split link chains. Would you recommend one?
Re: CB550 refurb
« Reply #78 on: October 13, 2024, 07:54:06 AM »
I don't know what mileage your bike has covered. As the engine is out have you checked the Primary Drive chain for wear, you can get an idea as to it's condition thought the sump hole.
I have to be honest I do not like the idea of a split link on a camchain, presumably you will have to take the barrel off to replace the base gaskets & liner O rings to avoid any chance of an oil leak.
FWIW as you have spoked your own wheels splitting the crank case is pretty straight forwards - its costs that mount of course as you go further into the engine.
Re: CB550 refurb
« Reply #79 on: October 13, 2024, 12:04:48 PM »
Yes I haven’t checked the primary drive chain yet Ted! I was just assuming by the way the engine ran that the lower end of the engine was not needing a lot of maintenance. The clock was reading in the region of 32,000 miles. I’m not daunted by having to split the cases but just thought I was not going down that route if I didn’t have to. So the primary drive chain wear might dictate the next move.
Re: CB550 refurb
« Reply #80 on: October 13, 2024, 05:37:08 PM »
At about £50 for the kawasaki one its one of those while you are there jobs(unlike the£110 Honda one!) The expensive bits are the rubber dampers in the primary drive as there are 8 of them
Re: CB550 refurb
« Reply #81 on: October 13, 2024, 05:59:08 PM »
Do you happen to know which compatible chain to order Bryan. Like the idea of paying less than half the price for a similar product!😜
Offline Seabeowner
Re: CB550 refurb
« Reply #82 on: October 13, 2024, 06:41:13 PM »
The Kawasaki primary chain is 92057-1011. I've fitted a couple. One has been in for about 5000 miles over the last 9 years. It was £39 then. But the 8 rubber dampers are another £35-£40. Plus the cam chain and the new seals and gaskets to it does mount up. I'd never split the bottom end of an engine until then and it was pretty strait forward with no special tools. A puller is needed to remove the primary shaft, but a long bolt with the correct thread was all that was needed.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Re: CB550 refurb
« Reply #83 on: October 13, 2024, 06:45:44 PM »
You don’t need a puller for the primary shaft…use the long, rear engine mount bolt as a make shift slide hammer 😁.And leave the alternator rotor on the crank.
Re: CB550 refurb
« Reply #84 on: October 13, 2024, 06:47:49 PM »
I have a brand new heavy duty cam chain if you are interested.
Offline Seabeowner
Re: CB550 refurb
« Reply #85 on: October 13, 2024, 06:54:55 PM »
That's what I said.
Re: CB550 refurb
« Reply #86 on: October 13, 2024, 07:02:14 PM »
Oops. Sorry missed that? Must drink less🫣. Ha, ha, but you didn’t mention the engine mount bolt. Ten jab no cummee back😀
« Last Edit: October 13, 2024, 07:04:17 PM by Sesman »
Re: CB550 refurb
« Reply #87 on: October 13, 2024, 09:18:38 PM »
Thanks very much for helpful comments and yes I will be interested in the cam chain.
Re: CB550 refurb
« Reply #88 on: October 13, 2024, 09:51:35 PM »
Thanks for the info, it’s a few years since I did the last one so it’s good to have the memory jogged!
Re: CB550 refurb
« Reply #89 on: October 13, 2024, 10:54:14 PM »
You do need to pull the alternator rotor if you want to swap the crank seal
