Author Topic: honda 550 tank badge grommets  (Read 3258 times)
beardylondon
« on: August 27, 2024, 03:53:46 PM »
Hi All
Please could someone advise best replacement source for the 4 x tank badge grommets on a 550, cheers.
Re: honda 550 tank badge grommets
« Reply #1 on: August 27, 2024, 04:18:51 PM »
Any Honda dealer but they aint cheap.
Just look up part number on cmsnl and ring your local dealer no p&p that way, dont ask them to look it up unless the parts man is near to retirement as they will just say Nah too old mate
« Reply #2 on: August 27, 2024, 04:59:49 PM »
I've used plastic badge cups - see my posted link on my badge restoration cheap for 10. They are like the old car badge fitting before the used self adhesive
They also fit the generator cover on a 500. I sent a pair to Ken using the others on my project.
Offline Seabeowner
« Reply #3 on: August 27, 2024, 06:51:56 PM »
I think nurse Julie on here has them.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #4 on: August 27, 2024, 06:58:22 PM »
I bought the genuine clips from NJ,  in the end I used these - they don't damage your paint when you fit them.
Seems easier to remove the badge if needed. I think 60p each is a bargain!
https://www.ebay.co.uk/itm/404681377390
« Last Edit: August 27, 2024, 07:04:52 PM by McCabe-Thiele (Ted) »
beardylondon
« Reply #5 on: August 27, 2024, 07:05:53 PM »
Thanks Ted, mine have completely disintegrated, hence I can’t emeasure them so please could you point me in the direction of the right size badge cups, thanks
« Reply #6 on: August 27, 2024, 07:45:09 PM »
The dimensions are in the below link, when you fit them into the tank they are the right length, they feel a little loose in the hole but when you fit the badge it's a pretty good fit - handy if your pins are slightly bent as they give and tighten up.
There might be some that have a sligthly larger o/d but most sellers do not show sizes I have found these suitable - nothing to stop you adding  some PTFE tape if you wanted to make them tighter. With the alternator having three lugs they are spot on for that location. I suspect the Hondas tank holes were probably based on Imperial at 3/16" so there might be some with that main o/d out there - old BL or Ford sizes.
« Last Edit: August 27, 2024, 08:06:41 PM by McCabe-Thiele (Ted) »
beardylondon
« Reply #7 on: August 27, 2024, 09:00:26 PM »
Thanks very much Ted!
