Author Topic: I need a Charles Atlas set of gym equipment.  (Read 8294 times)
Re: I need a Charles Atlas set of gym equipment.
« Reply #15 on: September 02, 2024, 09:20:35 AM »
TBH it was virtually impossible for me to get the 500 up on the center stand on my own. I managed it only once without my brother's help a few days ago.
A mate gave me a nice sized piece of 1/2" ply so I tried using it under the back wheel today whilst fitting an adjustable stopper for the center stand. It wasn't that easy but I did manage to get it up several times. On my 400 I just press down on the stand arm and a slight lift on the handle and it up.
I suspect I need to work more on my technique as it's too easy for me  to have it leaning to the left ( I put the side stand down as well for safety) so the right side of the stand is off the ground.
Definitely you've identified something there Ted. It makes a big difference to lifting them if not set onto both feet of the stand equally. You'll end up about 5 foot 4 with spinal compression trying it on just the left side of centre stand  ;D
It feels a little insecure as it starts to lean away from you, naturally you don't want to feel you're going to drop it on the other side too.
But putting the stand down until it touches the ground, then letting it tip over until the other leg touches down before exertion in going to the lifting part will maximise the leverage available to you.
« Reply #16 on: September 02, 2024, 11:17:43 AM »
You have hit the nail on the head K2-K6 (Nigel?) I have this fear of the bike tipping away from  me as I fall on top in slow motion being branded by two hot exhaust pipes.  :( :( :(
Marginally better than it falling on top of me. ;D ;D ;D
Ive started doing some easy exercises (easy who am I kidding) just bending my knees to lower myself down then back up again without using my hands on my knees to stand back up. I might try some Canadian Air Force Isometrics that I did in my youth.
« Reply #17 on: September 02, 2024, 12:17:22 PM »
Ted, think yoursen lucky mate, i have just started back gym getting ready for next Februaries bruce test for licence!!!
« Reply #18 on: September 02, 2024, 12:22:43 PM »
With your right foot on the stand lug and both of the centrestand feet on the ground, the bike should be quite stable before you start lifting. Only on level ground though!
