Author Topic: Upper brake hose length  (Read 6799 times)
Offline SteveW
« on: August 31, 2024, 05:43:35 PM »
Does anyone know the length of the upper brake hose for a 550 with UK bars please?
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
Re: Upper brake hose length
« Reply #1 on: August 31, 2024, 06:26:04 PM »
If it helps I can check my 500 that has UK bars, I think the length might be printed on the pipe. I'm out at the moment.
Offline SteveW
« Reply #2 on: August 31, 2024, 06:35:10 PM »
Thanks Ted, that would be great.
My 550 had US bars, just fitting UK bars to it.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #3 on: September 01, 2024, 12:10:14 AM »
Obviously my pipe is fitted so I have done my best to follow the upper hose route using a rubber pipe alongside it to measure the run.
Excluding the metal ends the actual flexi-pipe measures 10"/ 25.5 mm or thereabouts measuring from the master cylinder to the three way connector.  The Banjo fittings are a tad under 2" each measuring from the end of the Banjo to the end of the crimpet part where it attaches to the hose.
The total length including the fittings is approximately 14" in total end to end laid flat.  Our local car spares that sadly closed and never re-opened after covid listed  hoses in their parts books in various lengths with choice of fittings.
Fancy ones are listed on e-bay braided SS etc for both £48.90 .https://www.ebay.co.uk/itm/164647198327?fits=UKM_Make%3AHonda&_nkw=Honda+CB500+K+1+brake+hoses&itmmeta=01J6NB0WVBYPXV2J294E7P8A2R&hash=item2655bcde77:g:gaoAAOSwd3lmZt24&itmprp=enc%3AAQAJAAAA4HoV3kP08IDx%2BKZ9MfhVJKnKX08IrpX4dAjtiC1D5wAaIuyJ%2FBObOpLvstdUgKW2iiSqWzpgmYRSQnCLkzO4fhect%2FLtqVso4EGgCuT7ky4mhrBLpk%2B02ViqOLgmT4ieGDYlVEHVOc1Rs4z%2F9YnMHsphEtV%2Bx9V0nWDUGBTiIGcE9TqEJsc29W75bEyY4K1rX21fW5Q26OctkZtUAJuWROV%2FzVgZNCcsqy%2BGlVmGp5WrsoNyeUk7PY4tLKHoBUlBDmbRAkslwnH3fhYm6FNvdxxR2cLgWvgmsEm2AX7AkmWl%7Ctkp%3ABk9SR-TNg6u1ZA
« Last Edit: September 02, 2024, 07:43:24 AM by McCabe-Thiele (Ted) »
Offline SteveW
« Reply #4 on: September 01, 2024, 06:12:56 AM »
Thanks Ted, that’s perfect.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline TezzerTel
« Reply #5 on: September 11, 2024, 08:10:20 AM »
Have you found a easily found replacement?
I'm looking for one myself
Offline SteveW
« Reply #6 on: September 11, 2024, 02:12:20 PM »
Wemoto, part number AH8566 is for the two rubber hoses and the rigid pipe at the bottom.
I emailed them asking them for the length and they came back with 37cm and 40cm for the rubber hoses.
So they are for UK handlebars.
1980 CB650
1981 RD350LC
2011 Henry Hoover
Offline TezzerTel
« Reply #7 on: September 11, 2024, 11:59:48 PM »
That part number is coming back as a exhaust stud?
« Reply #8 on: September 12, 2024, 12:27:15 AM »
My measurements at 14" is about 35.6 mm not quite enough it seems  it's actually 37 cm so I was 1.4 cm short, sorry about that.
Offline SteveW
« Reply #9 on: September 12, 2024, 12:28:29 PM »
Don’t be, your measurements were perfect for me, I just wanted to be sure that I didn’t end up with the US length hoses. The upper US hose is another 10 cm longer, I’ve been using UK bars with a US top hose for the last couple of years. So I have this great loop of hose by the front lever that looks odd.
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #10 on: September 12, 2024, 06:00:48 PM »
I’m in exactly the same situation as you Steve with 550f bars fitted I have a hose at 40cm still waiting to be fitted.
Offline SteveW
« Reply #11 on: September 12, 2024, 08:23:05 PM »
Sorry AH8856
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #12 on: September 12, 2024, 08:35:58 PM »
Hi Steve,
The website does not appear to have a search faciity is there a link for the listing?
Is it via Wemoto?
« Last Edit: September 12, 2024, 08:45:47 PM by McCabe-Thiele (Ted) »
Offline SteveW
« Reply #13 on: September 12, 2024, 08:49:36 PM »
1980 CB650
1981 RD350LC
2011 Henry Hoover
« Reply #14 on: September 12, 2024, 09:05:13 PM »
Thanks Steve, looks a good price -  the solid caliper brake pipe look as though its a coated outer finish or is it just a generic photo?
