Author Topic: Rear hub d ring.  (Read 10167 times)
Rear hub d ring.
« on: September 03, 2024, 05:37:04 PM »
Hi folks, I think I am looking for rocking horse poo here but does anyone have or know where I can get a rear hub d ring part No 91261323000. Somebody had ones on here, I didn’t buy one then because I didn’t need one. Think it was Oddjob. I could maybe obtain an o ring 79 x 2.6mm rather than fit nothing.
Re: Rear hub d ring.
« Reply #1 on: September 03, 2024, 06:05:53 PM »
I bought a new one from Ken as mine had a side cut in it, proper D shape.
« Reply #2 on: September 03, 2024, 06:36:46 PM »
They have been long obsoleted and the few nos ones i had went years ago, somebody on the forum living in europe had some specially made but there was a minimum number and i think he sold them all
« Reply #3 on: September 03, 2024, 07:30:10 PM »
Yes Bryan just looked back and it was Erny that sourced them earlier this year.
Offline DomP
« Reply #4 on: September 03, 2024, 08:52:06 PM »
I used two thin orings next to each other to fill the gap which worked well as a substitute, I'll look up the size I ordered.
*58 ID x 2mm if I'm looking at the correct order in my shockingly long list of bike parts!
« Last Edit: September 03, 2024, 09:07:50 PM by DomP »
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #5 on: September 04, 2024, 08:04:03 AM »
Thanks Dom, I’ll probably do something similar because of the limited availability.
Offline DomP
« Reply #6 on: September 04, 2024, 09:56:57 AM »
Cheap as chips too
1975 XS650B
Offline Orcade-Ian
    • Older Vehicle Web
« Reply #7 on: September 04, 2024, 05:48:55 PM »
Hi Johnny,
Might be a bit of a long shot but I had special seals made for my Lake and Elliot trolley jack - different material but you never know.
http://www.stallard-engineering.co.uk/stories/other/Trolley%20Jack.htm
They were extremely helpful and many others have used their services using the link on my site.  I only bought 2 of the specials and some other 'off the shelf' seals.
They are Barnwell Services (http://www.barnwell.co.uk/) - might be worth an email or call and I'm sure that if they can help it could be useful to others.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
« Reply #8 on: September 04, 2024, 07:57:17 PM »
From what I can work out the D shaped seal is there to keep out water and dirt in the space between the the two hub parts that will move a little as the drive cushion rubbers compress and move back when accelerating & decelerating. Two narrower o rings sounds a good option. When assembling my 500 hub the D ring even though greased took some effort to push the part fully home.
« Reply #9 on: September 05, 2024, 08:31:43 AM »
Thanks guys, great option Ian, definitely worth a try and quite happy to buy a number of them if available to help others out.
Offline DomP
« Reply #10 on: September 05, 2024, 06:46:34 PM »
I'd be interested too
1975 XS650B
« Reply #11 on: September 05, 2024, 06:50:33 PM »
Two 2 mm wide O rings - 4 mm in total sounds wide but maybe not.
I've measured my old D ring it  is 2.35 mm thick and 3.97 wide, it had been fitted with the flat section down. Your solution looks pretty close iirc the inner hub section groove is not flat but more rounded.
« Last Edit: September 05, 2024, 07:10:12 PM by McCabe-Thiele (Ted) »
« Reply #12 on: September 05, 2024, 07:11:04 PM »
The d ring groove is about 4mm wide Ted.
« Reply #13 on: September 05, 2024, 07:17:06 PM »
My measurements were taken with calipers so I probably pinched the rubber a tad. I gave up trying to measure the diameter for obvious reasons. I think I've read the 58 size previously.
« Last Edit: September 05, 2024, 07:19:20 PM by McCabe-Thiele (Ted) »
« Reply #14 on: September 07, 2024, 10:16:42 AM »
Johnny, I've found a D ring, in a box of big O rings 😁😁😁😁.
PM me if still interested.
