Author Topic: Neutral switch.  (Read 2396 times)
Offline TIM1954
Neutral switch.
« on: September 08, 2024, 11:37:32 AM »
Having problems with the neutral light staying on when in gear on my K6. The bulb just dims but will not go out. As a new switch is about £50 I thought I would try and repair it. If you remove the araldite type sealer from the bottom of the switch very carefully( the base is plastic) and use a pair of circlip pliers or something similar, you can unscrew the plastic cover. Inside it is a very simple switch with a spring and some brass contacts and a tube to locate the spring.
I just cleaned the dirty and tarnished components and re - assembled and the switch worked perfectly.
Re: Neutral switch.
« Reply #1 on: September 08, 2024, 11:40:20 AM »
Great job Tim and saved yourself £50!
Re: Neutral switch.
« Reply #2 on: September 08, 2024, 11:50:14 AM »
Nice work!   I have done this before myself ... assuming it's a 750K6 and not a 175K6   ;D... the 175 is a different matter ..the springy contact always wears and breaks off.  (Similar switch on CB350K and 500/4)
Silly me it's in the 750 section  :-[
