Author Topic: Beginner Questions  (Read 5668 times)
Offline Mike_Berkshire
Beginner Questions
« on: September 20, 2024, 08:09:00 PM »
Hi, I have a couple of questions that are probably really basic but I don't want to damage anything due to lack of understanding in what Im doing. Im polishing the clutch casing and thought it makes sense to replace the 2 oil seals in it. Do I remove these by simply prying them out and push-fit some new ones? Also, I want to clean the oil strainer that sits above the sump pan (funnel shaped thing with a fine mesh in it). Does the wire mesh just pull out of the funnel shaped casting, it looks as if it has a black plastic ring at the edge. Thanks
Re: Beginner Questions
« Reply #1 on: September 20, 2024, 08:34:27 PM »
Yes, the strainer mesh is detachable and as you say the mesh has a plastic edge around it. It just pulls off of the funnel.
« Reply #2 on: September 20, 2024, 10:16:17 PM »
I would take care trying to remove the mesh unit as the outer rubber section  might have  become brittle with age.
Mine was full of filter mesh that cleaned off easily enough by squirting down cleaning fluid from the top.
IIRC if the seal part breaks  replacements might not be available.
This was mine - cleaned easiy without removal - assuming yours is like mine.
.500 mesh filter by Macabe Thiele, on Flickr
« Last Edit: September 20, 2024, 10:22:33 PM by McCabe-Thiele (Ted) »
« Reply #3 on: September 20, 2024, 10:24:42 PM »
Yes that’s it Ted. Thanks for the tip. Thanks for the reply too Julie; did the ‘yes, refer to the removal/ replacement of the oil seals. Mike
« Reply #4 on: September 20, 2024, 10:29:11 PM »
The strainers are £22 plus postage from DS - they were not listed when I cleaned mine probably a couple of years ago.
« Reply #5 on: September 20, 2024, 10:42:06 PM »
Exactly what bike is this, 500 only has 1 seal in clutch cover
« Reply #6 on: September 20, 2024, 10:43:27 PM »
No, I haven't answered the question about the seals as I can't remember ☺️☺️. I also have the strainers in stock if yours doesn't clean up OK or is knackered.
« Reply #7 on: September 20, 2024, 11:00:10 PM »
It's interesting that quite a few parts that seemed unavailable only a couple of years back are now being produced again, either that or I didn't look hard enough. That seems to be true for 400 & 500 parts.
« Reply #8 on: September 21, 2024, 10:08:36 AM »
Going back to the clutch casing oil seals my 500 had one for the  gear shaft, the second one was on the end of the clutch mechanism. The seal on the alloy section is I believe to keep water etc out of the coarse threaded actuator part. I managed to break mine when removing the seal that fits on the outside by being clumsy. Ash kindly sent me a replacement part.
I know the clutch mechanism was improved so your 550 might be different.
« Reply #9 on: September 21, 2024, 11:27:33 AM »
550 is completely different Ted, the operating mechanism is all in the clutch cover and only a very short pushrod, which is why i asked exactly which bike it was
« Last Edit: September 21, 2024, 11:29:15 AM by Bryanj »
« Reply #10 on: September 21, 2024, 12:50:41 PM »
It's always confusing with the 500 & 550 being banded together when they are quite different in so many ways aside from the 50cc or so in cubic capacity.
« Last Edit: September 21, 2024, 08:20:26 PM by McCabe-Thiele (Ted) »
« Reply #11 on: September 21, 2024, 07:31:35 PM »
Just saw your post Bryan. It’s. 76 K2 550
« Reply #12 on: September 21, 2024, 10:05:12 PM »
Change the kickstart seal, they tiny one on clutch mechanism rarely leaks and that mechanism can be a swine
« Reply #13 on: September 22, 2024, 02:03:06 PM »
Thanks Bryan. What is the best way to take out/replace the kickstart seal? Tge only seal I’ve replaced before is the fork seal.
« Reply #14 on: September 22, 2024, 02:25:49 PM »
Once the casing is off just lever out with large flat screwdiver being carefull not to gouge the casing hole
