Author Topic: Oil pipe sump oils trainer and engine spacers  (Read 2511 times)
Offline Gary400/4
« on: October 04, 2024, 03:32:51 PM »
Hello I am at present restoring a CB550F I have the engine rebuilt into the frame, but still require a couple of engine spacers collars, the collars are at the rear of the engine and upper of 10 mm hole diameter and a lower collar with a 12 mm hole for the lower bar. or the dimensions so as I can get a couple machined. I alo require some suitable heat resistant oil pipe, for the oil strainer in the sump pan. It is part number 15155333000 but is not available anymore. Any suitable alternative pipe I would welcome the information.
Offline Gary400/4
Re: Oil pipe sump oils strainer and engine spacers
« Reply #1 on: October 04, 2024, 03:34:41 PM »
Correction in my title spelling
Re: Oil pipe sump oils trainer and engine spacers
« Reply #2 on: October 04, 2024, 05:04:00 PM »
A former member here makes SS ones at sensible prices his name is Max. If you want contact information PM me.
