Author Topic: Cylinder head/barrels  (Read 4122 times)
Offline Acro1985
« on: October 05, 2024, 05:29:08 PM »
Does anyone have any tips or tricks for cleaning up the mating surfaces on the top of the barrels and bottom of the cylinder head where the gasket goes. I tried petrol and wd40 with a soft cloth but it hasn't really done anything
Offline DomP
Re: Cylinder head/barrels
« Reply #1 on: October 05, 2024, 05:55:07 PM »
I got my barrels skimmed partly because I'd replaced a few liners which Bryan rebored for me and they needed flushing up on the mating face.  Also help to compress the o rings on the oil galleries that are known to be too thin in the supplied Vesrah gasket set.
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Offline SteveW
« Reply #2 on: October 05, 2024, 06:19:37 PM »
Sheet of glass and fine grinding paste.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
« Reply #3 on: October 05, 2024, 06:31:29 PM »
If it’s only staining/discolouration don’t be concerned. The gaskets are there for a reason.
Offline Murf
« Reply #4 on: October 20, 2024, 01:55:26 PM »
You do need to remove all traces of the old Gaskets, I use a very flat scraper I made years ago, it’s about 30 mm wide and 3mm thick, it is blunt with the end ground 90 deg to the sides, the end  to flat side corner is used for scraping. With careful use this type of scraper  will remove gasket material but no metal.  After scraping run your fingers over the surfaces to find any remaining bits off gasket.  I use a  vacuum cleaner held close to the scraper to suck up the bits and stop them falling down oil ways or into the cylinders.
« Reply #5 on: October 20, 2024, 04:01:20 PM »
As has been said most of it looks like staining, I had my 500 head skimmed to the lowest amount by a fancy machine it was about 3 tho of an inch. I used some gasket remover spray for the last stubborn remnant and a plastic scrape tool.
