Author Topic: Honda CB400NA Superdream - new money puddle.  (Read 196560 times)
Re: Honda CB400NA Superdream - new money puddle.
« Reply #270 on: June 03, 2026, 04:39:31 PM »
Perhaps a different situation, however an acquaintance of mine had a pacemaker fitted four or five years ago and, after a recuperation period, not only kept his car and motorcycles licences but was also able to continue driving private hire (taxi) vehicles and a minibus for a local charity.
Thanks for that flatfour, the Consultant I spoke to recently did say my Driving Licence would not be affected, I was under a duty to inform my insurers of course.
« Reply #271 on: June 03, 2026, 04:39:48 PM »
Mate of mine whilst working for Asda was delivering to Penny Lane, Asda, yes that Penny Lane. He had a heart attack and died, luckily for him the staff had only just completed some defibulator training and had a brand new machine on the premises. He died 3 times whilst at the store and the staff brought him back each time. Went into hospital, had a stent fitted and eventually had a pacemaker fitted. Only 8% of his left ventricle was working. He lost every license he had, HGV, PSV, car and bike. Eventually they returned his car one back but that was all. Admittedly his was an extreme case and I suppose each case is decided on it's merits, just don't go in there blind to the possible consequences is all I'm saying.
« Reply #272 on: June 04, 2026, 07:45:49 PM »
Penny Lane. My father in law had a fish and chip shop in Penny lane back in the late 50s and 60s. He once clipped the ear of a cheeky young pup by the name of Lennon. They didn’t have a defibrillator machine.
I could tell you a little about the development of rhythm detection algorithms using Fourier series….but won’t.
« Reply #273 on: June 04, 2026, 09:49:04 PM »
Managed a couple of half hour stints at restoring some shine on the left side engine casing.
Still needs a lot more work but it's a start, I'm using a pair of  light blue 400 plastic disc wheels to start with.
.PXL_20260603_070837815 by Macabe Thiele, on Flickr
PXL_20260604_183944143 by Macabe Thiele, on Flickr
« Reply #274 on: June 05, 2026, 07:56:44 AM »
Great start, Ted. Out of interest, from where did you source your “ blue wheels”.The items I purchased are very poor and break down in a few minutes.
« Reply #275 on: June 05, 2026, 08:15:52 AM »
Hi Phil, I've used ebay & Amazon, only time I have had the wheels fall to bits is when I've accidenally moved the speed control or applied too much pressure.
I find position 3 on my Von Haus tool is usually about right, I tend to use two wheels at a time. IIRC I found a seller that sells the colours individually. Checking back today that seller has ended the listing.
I tend to use 400, 600 & 1000 most of the time.
Ken might know a supplier of quality versions.
Update I'm assuming you have them mounted the right way round on the shaft.
« Last Edit: June 05, 2026, 05:18:20 PM by McCabe-Thiele (Ted) »
« Reply #277 on: June 05, 2026, 07:27:22 PM »
Can I just add. Ted, lovely job. If you want it even better the only thing I'd suggest is to redo the really small areas near the screw holes. You can see they are slightly rougher than the rest. It may polish out nicely but the smoother you get those areas the better the end result is.
I'd also strongly suggest getting the extension lead for the Dremel. I use the Dremel 4300 IIRC. It has a metre long extension lead which is much lighter then the main tool so lets you use it longer and being thinner it also allows you to get into areas the main tool struggles with. Seriously, once you've used one you'll never go back to using the main tool. I used to have loads of them spares but ended up giving them away, everytime I send a dremel back under warranty they'd send the entire kit again with another extension. If I can find one you can have one foc.
Dremel 4250 is the replacement for the Dremel 4300.
https://www.amazon.co.uk/Dremel-4250-Attachments-Accessories-5-000-35-000/dp/B0949DP1J8/ref=sxin_12_sbv_search_btf_mod_primary_new?aref=913wQJZIhQ&content-id=amzn1.sym.0cf85714-a5b0-4d96-9050-d0dce9037023%3Aamzn1.sym.0cf85714-a5b0-4d96-9050-d0dce9037023&crid=ZW3NT56YZ4RB&cv_ct_cx=dremel%2B4250&keywords=dremel%2B4250&pd_rd_i=B0949DP1J8&pd_rd_r=c6aebd69-0c92-49a8-8bc6-229916ab9493&pd_rd_w=dOu9R&pd_rd_wg=evhUe&pf_rd_p=0cf85714-a5b0-4d96-9050-d0dce9037023&pf_rd_r=TMZ9MBBP8QDQ55R5JEX3&qid=1780684122&sbo=RZvfv%2F%2FHxDF%2BO5021pAnSA%3D%3D&sprefix=dremel%2B4250%2Caps%2C131&sr=1-1-9131241a-a358-4619-a7b8-0f5a65d91d81&th=1
And the extension is called a flexi shaft.
https://www.amazon.co.uk/Dremel-Multi-Purpose-Extension-Sharpening-Woodworking/dp/B008ETGPOY/ref=sr_1_18?crid=ZW3NT56YZ4RB&dib=eyJ2IjoiMSJ9.wc_7qGE_7sQ1KpllTMo_VEb9_DUCsi5VzDhF3KFf5dgI9aXSavcI0ubtJ9S18d5aDvIT5DFTWQgAQnjWPBXqMsuzS8TjXxCQB1nnqcLCP-69mfPmAAMUqyBwKR-NRkYRkHFWzO-Dmj4rnhinXc2ox4B8kIooT43CTsUTw9f43Mr2vSnRjCRsgMTPaME8eUb2YUVFxi2Iz1fkBRIOGW4Dk3OFNh8EIoY0Q7cxL-6_n5wbXFHjoAbAmIU2fkvlgoAiTbcUDSM3Ojl2m-767VUhDGyU7o70Pbfw8D4I5iLXojA.w8_PdqDr56PFL8gaky6aJUYug0eE7Gc5VVBmAwuTL20&dib_tag=se&keywords=dremel+4250&qid=1780684223&sprefix=dremel+4250%2Caps%2C131&sr=8-18&ufe=app_do%3Aamzn1.fos.7bbc1e72-d5e0-4378-81de-b15e5f172cd1
« Last Edit: June 05, 2026, 07:30:44 PM by Oddjob »
« Reply #278 on: June 05, 2026, 08:02:59 PM »
It's a work in progress Ken, I'm far from finished!
I bought the Von Haus version (recommended by a member here) as I could not justify the price of a genuine Dremel kit. I don't think Von Haus do an extension lead.
« Reply #279 on: June 05, 2026, 10:09:16 PM »
Evidently the flexi-shaft fits the Von Haus. From what I've read anyway. It's not as powerful as the 3250 and the rev range isn't as good but it's cheap. The problem is what happens if or when it burns out. The Dremel gets a 2 year warranty and I can say for a fact it's very very good. No questions asked. Plus as I said they tend to return the full kit if you've bought a full kit first off. So extra tools and flex for free.
« Reply #280 on: August 13, 2026, 03:03:01 PM »
My BiL came today to help fit my engine in the frame.
Dave jacked it up whilst I tilted it to get it in place, took about 30 ins with faffing about & being careful.
Just fitted the rear and front mounting bolts in place, I need to check a few things like bolt orientation before I tighten up the flange nuts.
#PXL_20260813_111906403 by Macabe Thiele, on Flickr
« Reply #281 on: August 13, 2026, 03:47:42 PM »
Always a major victory when the engine goes back in, the end is in sight :)
« Reply #282 on: August 13, 2026, 03:55:19 PM »
Try doing this Ted. We found that if the engine bolts were tightened with no regard to engine position the engine buzzed or vibrated. Try loosely fitting all the bolts, lift the engine a little with the jack and then check every bolt. If every bolt slides in and out the engines in the right position, if even one drags or resists being moved the engines needs to be repositioned slightly until they all move easily. Only then do you tighten the nuts. It’s a bit of a faff but the results seem worth it.
« Reply #283 on: August 13, 2026, 04:48:53 PM »
Good work Ted, and decent progress.
At least you're not getting cold in this weather currently  ;D
« Reply #284 on: August 13, 2026, 04:52:44 PM »
Thanks Ken, does the top double triangular block bracket get fitted last?
