Author Topic: Help with O ring identification please  (Read 2949 times)
Offline Mike_Berkshire
« on: October 15, 2024, 04:13:16 PM »
I have just received a Vesrah gasket set for my '76 K2 550 and I have been sorting through the pack of O rings to work out what is what. DS sticking packing tape over the parts list on the back didn't help. I have all the O rings sorted and Im left with one query. There are 3 O rings given as part number 91303-035-000. Two of these are for around the oil control valves where crank case joins the barrels. I cant for the life of me work out what the third one is for; can anyone tell me?
Also, I rather foolishly believed that the plastic sealing discs that go in the head and cover the head bolts would be in the kit. Not so and at £5 each a bit of a shock. I have found 4 of the old ones but the other 4 must have ended up in the bin. I assume its advisable not to reuse these old ones or work with a mixed set?
Re: Help with O ring identification please
« Reply #1 on: October 15, 2024, 04:53:40 PM »
I think it's for the tacho drive Mike or have you accounted for that one? . No, don't use the original head sealing washers (pucks as they are called).
« Reply #2 on: October 15, 2024, 06:03:16 PM »
Or the clutch case operating arm shaft?
« Reply #3 on: October 15, 2024, 07:32:57 PM »
If you mean the pontefract cakes, yeah, just buy some new ones don’t reuse old ones. You might as well, you’re in there and there’s a chance that you don’t match the right one to the right hole and cause leakage etc and have to strip it down again
That other o ring, it’s not for the gear change lever through the case is it?
