Author Topic: CB360 1975 Starter Motor Issue  (Read 9738 times)
Offline Madagas2002
« on: October 16, 2024, 09:13:01 PM »
Hi All,
The starter motor on my bike is refusing to turn over.
The solenoid is clicking but nothing at the motor.
All the other electrics are working. I've also checked the earths.
The battery is fully charged.
A curious thing is the kick start turns, but is sticking, which it has never done before.
Could these issues be related?
Thanks in advance for any help and advice.
John
Re: CB360 1975 Starter Motor Issue
« Reply #1 on: October 16, 2024, 09:16:35 PM »
Personally I would remove the starter motor and test it using a slave battery - I have an old car battery that I use.
« Reply #2 on: October 16, 2024, 09:23:55 PM »
As a quick test I would be tempted to try manual switching method.
« Reply #3 on: October 16, 2024, 09:51:02 PM »
Solenoids fail more often than starters, take a big old screwdriver and use it to bridge the two big contacts on the solenoid, big spark and starter turns you need new solenoid, no spark and no turn strip the starter as brushes could be worn out
« Reply #4 on: October 17, 2024, 07:12:37 AM »
I would also look at the sprag clutch on the alternator rotor.
« Reply #5 on: October 17, 2024, 07:27:23 AM »
Strip the solenoid. You will probably find that the copper contact strip mounted on the solenoid shaft is corroded or arc burnt to an extent that it doesn’t make good  contact with the fixed pins.
« Reply #6 on: October 17, 2024, 08:24:13 AM »
Then if it is damaged you can  turn it upside down.
Offline Madagas2002
« Reply #7 on: October 17, 2024, 08:39:55 AM »
Hi All,
Thanks for your help.
I put a wire across the solenoid terminals and got a spark, but the starter motor didn't turn.
« Reply #8 on: October 17, 2024, 08:44:55 AM »
Which obviously points to the motor.
« Reply #9 on: October 17, 2024, 08:59:29 AM »
Or the starter clutch... any nasty noises when it was working?
Offline Madagas2002
« Reply #10 on: October 17, 2024, 09:24:00 AM »
I used a refurb kit on the starter and I always thought it sounded slow, but no nasty noises.
I probably need to take the starter motor off (or hook a battery directly to it) and see if that's the problem.
Would a jump starter pack work instead of a battery?
« Last Edit: October 17, 2024, 09:25:48 AM by Madagas2002 »
« Reply #11 on: October 17, 2024, 09:27:25 AM »
Agree
« Reply #12 on: October 17, 2024, 10:22:44 AM »
Just a thought, but are you sure the battery is delivering amps? Although the off load voltage may indicate a healthy battery, it isn’t necessarily correct. A duff battery will create the symptoms you have described. Using a known healthy battery would be helpful in the first instance before moving on to the sole load and starter/sprag assembly. Just a suggestion.
« Reply #13 on: October 17, 2024, 10:24:30 AM »
Just read through the posts and Teds already suggested this. I’m not sure if the kickstarter binding is of importance or not.
Offline SteveW
« Reply #14 on: October 17, 2024, 12:52:59 PM »
Might be worth removing starter and opening it up, this is what my 650 looked like.
It was making a terrible noise when trying to start the bike, once cleaned up it was fine.
1980 CB650
2000 CBR929RR Fireblade
1966 Lambretta LI150 Series 3
1981 RD350LC
1972 Raleigh Chopper
1974 Raleigh Tomahawk
2011 Henry Hoover
