Author Topic: Handlebar clamps  (Read 3076 times)
Offline TezzerTel
Handlebar clamps
« on: October 23, 2024, 07:14:20 PM »
I've just cleaned my handle bar clamps ready to refit them and noticed a dot to one side. I'm guessing this is for orientation but do they go fore or aft?
Re: Handlebar clamps
« Reply #1 on: October 23, 2024, 07:24:12 PM »
I believe that faces towards the front. If you place them on a flat piece of glass that mark will be on the higher part of the casting at the front.
IIRC you torque the front first then the rear, similar to the lower fork axle clamps.
Someone here will confirm I suspect it's covered in the manual.
« Reply #2 on: October 23, 2024, 08:32:52 PM »
As Ted says, tighten front first, then the back, there will be a small gap at join at the back once clamped, which is correct.
« Reply #3 on: October 23, 2024, 09:41:49 PM »
It is in the pdi and setup sheets in Ashs dropbox
Offline TezzerTel
« Reply #4 on: October 23, 2024, 10:56:17 PM »
Thanks all
