Author Topic: Not really a bodge more a half done fix?  (Read 5627 times)
Re: Not really a bodge more a half done fix?
« Reply #15 on: October 31, 2024, 04:04:16 PM »
I would have fitted a 27deg angled banjo there, or maybe a straight fitting with 90deg swivel end on the hose
The SS 13 mm  pipe clip is one I've had for a few years that was too big for the job I bought it for.
I ended up using a similar pair of 10mm ones - can't remember what the jb was now.
I'll google a 27 deg banjo and see what one looks like, is it an angled fitting for the pipe itself?
« Last Edit: October 31, 2024, 04:05:49 PM by McCabe-Thiele (Ted) »
« Reply #16 on: October 31, 2024, 05:02:01 PM »
Looks a lot better!
Nb You seem to be missing the rubber covers that stop muck getting into the fork slider seal.
« Reply #17 on: October 31, 2024, 05:05:05 PM »
Ted go to fleabay and type in an3 brake pipe fittings to see a lot of the types you can get mate
« Reply #18 on: October 31, 2024, 05:20:23 PM »
Looks a lot better!
It had split gaiters fitted to hide some pitting, I've cut them off. No fork stanchion drain holes fitted to my model. It will get a fork rebuild, am hoping it does not need Hard Chroming.
« Last Edit: October 31, 2024, 08:27:44 PM by McCabe-Thiele (Ted) »
