Author Topic: Vapour blasting paint or not paint  (Read 20404 times)
Offline Ken4004
« on: November 05, 2024, 06:18:11 PM »
When I originally stripped my engine down and had it vapour blasted I made the decision not to paint it because the finish was so good.
My reasoning for this was due to the fact that during the vapour blasting  the surface gets bombarded with the particles and hardens the surface , my I tension is to treat it with AC 50 to be on the safe side.
Let me know your thoughts on the subject, worst case scenario the engine will have to come out and get sprayed .
Re: Vapour blasting paint or not paint
« Reply #1 on: November 05, 2024, 07:12:05 PM »
If you are going to use it regularly and depending on where it's stored when not in use, oxidation sets in quite quickly and it looks bloody awful. It's very easy to keep a painted engine clean, just a bucket of hot soapy water, job done.
Use Simoniz SIMVHT31D, it's a perfect match to original.
« Reply #2 on: November 05, 2024, 07:22:05 PM »
Aluminium does not resist oxidation very well, even if you do not expose it to the salt on our roads it also reacts with acid rain not helped by the heat cycles of an engine. AC50 probably works to slow down the corrosion but it will dull so TBH I'm with Julie paint it like it was originally - Mr  Honda knew what he was doing.
Offline Ken4004
« Reply #3 on: November 05, 2024, 07:43:28 PM »
Ok thanks I’ll look into a paint job once I have got it running I’ll add the job to the long list all part of the learning curve.Not too bad to strip the engine down once you have done it before .
I found it very interesting especially the gear change mechanism form memory there were about 40 parts to it so too lots of photos while I took it apart.
« Reply #4 on: November 06, 2024, 08:57:18 AM »
You can paint it as a complete engine, the problem would be not being able to heat cure the casings, block & head would be fine. There are some engine paints that will become petrol proof without the heating process. My BiL did his engine on a Fireblade with a US sourced block enamel.
Offline Ken4004
« Reply #5 on: November 06, 2024, 02:15:29 PM »
I wonder if running the engine for a short time will cure the paint food for thought,
It sounds like a lot of hassle but I don’t really mind taking the engine out again if that’s what it needs.
« Reply #6 on: November 06, 2024, 03:04:05 PM »
It may cure the head and barrels after a while but it won't cure the crank cases as they don't get hot enough.
Offline Seabeowner
« Reply #7 on: November 06, 2024, 06:29:55 PM »
I've left the head on my main rider 500 unpainted for 20 years and never had any oxidation and it cleans up fine and no worries of flaky paint. But always painted the cases.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline ozzybud
« Reply #8 on: November 07, 2024, 01:17:40 PM »
Spray can paint unless it's a 2k mix never fully cures! It dries via evaporation of the solvent . Putting the Cases in the oven to "cure" is a waste of time and energy. It does not make the paint any more durable or chemically resistant. If you want a paint that will withstand time and chemically resistant use an Epoxy or a 2 part paint with a catalyzed property
 These paints cure via chemical reaction and are durable for the long haul.
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #9 on: November 07, 2024, 01:41:19 PM »
Through lots of personal experience, I would dispute most of what you have said. The Simoniz engine enamel (SIMVHT31D) is very hard wearing, retains it colour and finish well, it's easy to keep clean. It is highly fuel and chemical resistant but, if you have a continual fuel leak on it, fix the leak before it damages the paint. Follow the instructions on the can and it's perfect.
« Last Edit: November 07, 2024, 01:45:46 PM by Nurse Julie »
Offline ozzybud
« Reply #10 on: November 07, 2024, 01:56:34 PM »
It's not my opinion . It's Science.
Spray can paint is just pigment lying on the surface
The. Original honda case paint was some type of epoxy. Fuel can be on it forever and it does not lift. It will discolor a bit.
« Last Edit: November 07, 2024, 01:58:40 PM by ozzybud »
« Reply #11 on: November 07, 2024, 02:03:09 PM »
Simonize VHT is an Enamel paint, heat curing at the specified levels drives out all the solvent so I disagree with your wide ranging  conclusion.
You could argue that if your 2 part paint is not a 100% eutectic mixture the catalyst action might fail. There are enamel engine block paints that will self cure over time without the need for oven baking to make them petrol proof.
Offline ozzybud
« Reply #12 on: November 07, 2024, 02:09:58 PM »
99% of the solvent s flash off in 24 hours naturally.
I can guarantee you this paint if left out in the elements will oxidized and degrade within 5  years if left out in the elements. And drop some acetone on it and it will immediately dissolve..
« Last Edit: November 07, 2024, 02:18:36 PM by ozzybud »
« Reply #13 on: November 07, 2024, 02:18:56 PM »
They have been using water as the solvent base on car body  paint for quite a few years now, I've never had diesel or petrol strip the paint off when fueling as the paints are oven dried at the factory.
« Last Edit: November 07, 2024, 02:25:40 PM by McCabe-Thiele (Ted) »
« Reply #14 on: November 07, 2024, 02:29:28 PM »
There is no worse storage for bikes than a typical UK  brick built garage in the winter, the Simoniz stays perfect and shows no sign of oxidation after many years. As for acetone, why would you get that near any paint, that's just asking for trouble, the same as if you dropped battery acid on paint?
The main point is that a good quality enamel paint out of a spray can gives an excellent finish and is very user friendly for the DIY'er, which most are on this forum.
« Last Edit: November 07, 2024, 02:32:46 PM by Nurse Julie »
