Author Topic: Vapour blasting paint or not paint  (Read 20413 times)
Offline ozzybud
Re: Vapour blasting paint or not paint
« Reply #15 on: November 07, 2024, 02:35:26 PM »
They have been using water as the solvent base on car body  paint for quite a few years now, I've never had diesel or petrol strip the paint off when fueling as the paints are oven dried at the fact
ory.
Water borne paints are catalyzed
1976 Z50 PARAKEET YELLOW
1970 CT70 CANDY SAPPHIRE BLUE
1971 CT70H CANDY TOPAZ ORANGE
1972 CT70H CANDY EMERALD GREEN
1973 CL200 CANDY RIVERA BLUE
1973 CB350F FLAKE MATADOR RED
1974 CB350F GLORY BLUE BLACK
1975 CB360T LIGHT RUBY RED
1975 CB400F VARNISH BLUE
1975 CB550 FLAKE SUNRISE ORANGE
1976 CB750F CANDY ANTARES RED
« Reply #16 on: November 07, 2024, 02:45:32 PM »
Do you know the chemical name of the Catalyst they use?
Is it not likely that the same or a similar catalyst is used in Simonize Engine Enamel?
https://www.simoniz.uk/products/engine-enamel/
« Last Edit: November 07, 2024, 04:38:41 PM by McCabe-Thiele (Ted) »
« Reply #17 on: November 07, 2024, 02:56:46 PM »
This is an interesting background to the complexity of paint technology, I will not even go down the route of what surfactants do as I have never fully understood them.
.https://www.dakkadakka.com/wiki/en/The_Chemistry_of_Paint
Offline ozzybud
« Reply #18 on: November 07, 2024, 03:11:49 PM »
Spray can paint unless it's a 2k mix never fully cures! It dries via evaporation of the solvent . Putting the Cases in the oven to "cure" is a waste of time and energy. It does not make the paint any more durable or chemically resistant. If you want a paint that will withstand time and chemically resistant use an Epoxy or a 2 part paint with a catalyzed property
 These paints cure via chemical reaction and are durable for the long haul.
Simonize VHT is an Enamel paint, heat curing at the specified levels drives out all the solvent so I disagree with your wide ranging  conclusion.
You could argue that if your 2 part paint is not a 100% eutectic mixture the catalyst action might fail. There are enamel engine block paints that will self cure over time without the need for oven baking to make them petrol proof.
99% of the solvent s flash off in 24 hours naturally.
I can guarantee you this paint if left out in the elements will oxidized and degrade within 5  years if left out in the elements. And drop some acetone on it and it will immediately dissolve..
There is no worse storage for bikes than a typical UK  brick built garage in the winter, the Simoniz stays perfect and shows no sign of oxidation after many years. As for acetone, why would you get that near any paint, that's just asking for trouble, the same as if you dropped battery acid on paint?
The main point is that a good quality enamel paint out of a spray can gives an excellent finish and is very user friendly for the DIY'er, which most are on this forum.
I was just using acetone as an example.
I totally agree with you about us DIY'ers. As with most of our bikes not are used for fair weather riding and poop cams are the way to go.
But the baking in the oven adds nothing.
Offline ozzybud
« Reply #19 on: November 07, 2024, 03:12:40 PM »
Is it not likely that the same or a similar catalyst is used in Sinonize Engine Enamel?
Isosyanide
« Reply #20 on: November 07, 2024, 03:31:49 PM »
Isosyanide
Isocyanate
Simoniz Engine enamel is 1k system and doesn't have a curing agent in it.
« Reply #21 on: November 07, 2024, 03:41:11 PM »
The baking in the oven you say does nothing I disagree, why does the manufacturer specify the oven cure then?
On some US block paints there is an option to heat cure or air dry, the difference is about 3-4 months above a certain minimum room temperature.
Offline ozzybud
« Reply #22 on: November 08, 2024, 12:30:48 AM »
Maybe to clarify my point about types of paint. i will use different words to explain my point. lets use Hardness and cure.
ill compare it to Asphalt and Cement.
Any paint that comes out of spray can less The 2K types, are like Asphalt . re-introduce a petroleum product to it (oil, gas, etc) and it will return to a fluid state. This paint dries to the touch in an hour and is 99% cured or hardened in 24 hours when all the solvent evaporates. It never gets any Harder. Only the 1%. It has zero defense against oxidizing and degradation from the elements. If you are OK with a 5-10 year life use this kind of paint. Honda did not!
A paint that is 2 parts and hardens with a catalyst is like Cement. It hardens due to a chemical reaction and lime is the catalyst. you can pour water,oil, gas on in and it will not affect it .
This isn't just my thoughts or theories. This is Science. I have been in the painting business a long time.
The entire  industrial world uses catalyzed paint on just about everything. Bridges,Buildings, light equipment, heavy equipment,cars,bikes,spaceships airplanes. The list could go on forever. They are not using any paint that is drying via evaporation for very good reasons! Longevity and durability.
« Last Edit: November 08, 2024, 04:50:16 AM by ozzybud »
« Reply #23 on: November 08, 2024, 08:58:05 PM »
I restored a Matchless G3 about 25 year ago I painted the entire bike with an old fashioned enamel paint. The tickler regularly sticks in the Amal carb and before you know it the petrol is pouring from the carb onto the cover covering the engine plates. It is unmarked as yet I am glad to say.
Offline TezzerTel
« Reply #24 on: November 12, 2024, 08:10:27 AM »
I'm convinced that the Simoniz is the way to go but I've a couple of questions-
Is it difficult to get into all the cooling fins/channels? There's lots especially in the cylinder head
How many tins for a complete engine?
« Reply #25 on: November 12, 2024, 08:38:43 AM »
2 cans for a complete engine as 3 light coats are needed and it's pretty easy getting in between the fins.
« Reply #26 on: November 12, 2024, 10:51:00 AM »
I used a small paint brush and painted into the deep part of the fins first using some aerosol paint sprayed into a container. If you then use the spray afterwards it avoids having too much paint building up on the outer edge of the fins.
Offline Skoti
« Reply #27 on: November 12, 2024, 11:32:18 AM »
Aye Ted,
I done the same as you, but used Dupli Color Supertherm,  just painted all the cylinder fins with a small touch up brush.
https://www.colorshop.cz/en/sprays/dupli-color-supertherm-heat-resistant-paint-800-c-silver-spray-150ml/
It's good stuff and didn't leave brush marks.
« Last Edit: November 12, 2024, 08:22:22 PM by Skoti »
Skoti
1976 Honda CB750F1
