Author Topic: PD46 Float Bowl Woes  (Read 3472 times)
Offline PennoK3
« on: November 09, 2024, 12:48:42 PM »
Standard leaky float bowl procedure of replacing float needles but one carburettor continued to overflow.   Removed the float bowl and filled it with petrol and it appears to be a leak through the brass overflow pipe in the float bowl rather than the float needle   I assume there isn't any way to replace this and it will mean a replacement float bowl?
Re: PD46 Float Bowl Woes
« Reply #1 on: November 09, 2024, 01:16:33 PM »
I've heard a lot of people solder the brass tube with very good success.
Offline PennoK3
« Reply #2 on: November 09, 2024, 01:47:14 PM »
Yes, that just popped int my head on a dog walk, worth a try :D
« Reply #3 on: November 09, 2024, 03:37:45 PM »
I have always wondered if theold tube could be removed, the hole tapped and generic tube tapped to suit then sealed in, a lot of work if you can get another bowl!
What bike and which carb so when i get back from holiday in a couple of weeks i can look in my scrap box
Offline PennoK3
« Reply #4 on: November 09, 2024, 04:21:30 PM »
Tried a good coat of solder on the tube but after watching it drain I think it is actually weeping through the joint between the pipe and the float bowl.
Offline PennoK3
« Reply #5 on: November 09, 2024, 04:22:37 PM »
550 K3 PD46 Carb.
« Reply #6 on: November 09, 2024, 05:23:32 PM »
I will look when i get home after holiday, there are 2 types, all will fit but drain plug might be on wrong side
Offline PennoK3
« Reply #7 on: November 09, 2024, 05:28:27 PM »
Many thanks.
