Author Topic: The bolt that holds the advance unit on.  (Read 7868 times)
Offline nairb
« on: November 09, 2024, 08:55:11 PM »
A simple question..... which way does the bolt that holds the timing advance unit on to the front camshaft, Undo.
Looks to be the normal way - spanner anti-clockwise.
See pic below
The Clymer manual does not seem to say.  I would rather get it right.
Ta
Nairb
cb550k3, cl450k5, re5m, xs650xs2, mt500, kettle, gt550 x2, gt380 Kz750 twin, cb360K0 and an old working bicycle
Offline DomP
Re: The bolt that holds the advance unit on.
« Reply #1 on: November 09, 2024, 08:58:48 PM »
Correct!
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
« Reply #2 on: November 09, 2024, 09:59:20 PM »
I think most workshop manuals do not mention if a bolt is a normal right hand thread (RHT) so anti-clockwise is to undo the RHT bolt as DomP has said.
I think it's fair to say that only where a thread is a left hand thread (LHT) does a manual mention it as to undo a LHT needs to be turned clockwise.
Only left hand thread that I can think of that I have encountered is the rear bearing retaining ring on a 500, that's mentioned both on here & in the manuals.
Offline nairb
« Reply #3 on: November 11, 2024, 12:50:19 AM »
It's on pretty tight which made me think if I was undoing the right way.  I did check the p/n and found a pic which showed which way the thread went.
I remember a Kawasaki rotor bolt that had to be undone the opposite way and the manual did say this.
Old age can make you unsure.... best to ask.
Nairb
