Author Topic: Removing the front wheel on a Superdream wtf?  (Read 1307 times)
« on: November 09, 2024, 10:11:14 PM »
Now that the engine is out with the bike turned round on the ramp and back on the center stand  I have found a snag!
On my 500 I put the dual type Scissor Jack under the bottom of the frame tubes, clamped the rear wheel, strap over the rear of the frame ,  as I raised  the Jack the front wheel lifted up, slid the panel out, wheel removed.
On the Superdream there are no tubes on the bottom of the frame, can't really figure out where to jack up the bike to raise the front wheel.
Only thing I can think of at the moment is do I take out the rear wheel then try pulling down on the rear of the swing arm  using a strap to tilt the front end upwards?
« Last Edit: November 09, 2024, 10:36:25 PM by McCabe-Thiele (Ted) »
Re: Removing the front wheel on a Superdream wtf?
« Reply #1 on: November 10, 2024, 10:25:41 AM »
I must have been too tired last night to see the obvious - removed the calipers, discs, fender, that lighted the front end.
Undid the main axle bolt then the one clamp on the right side, the front end was now almost off the ground.
Out the wheel  came in less than 20 minutes!
« Last Edit: November 10, 2024, 10:31:10 AM by McCabe-Thiele (Ted) »
