Author Topic: Honda 400 4 head light birds nest  (Read 6356 times)
Offline Ken4004
« on: November 11, 2024, 06:32:16 PM »
Hi everyone just finishing off the wiring and have been changing all the connectors on the wiring loom, I just wondered if anyone has a good method of tidying up the wiring in the headlight shell.
I can’t believe it’s all just pushed in there must Be a preferred method of dressing the cables to allow the headlight to be fitted easily , looking forward to your thought on the subject.
Re: Honda 400 4 head light birds nest
« Reply #1 on: November 11, 2024, 06:37:07 PM »
Wait till spring, hopefully a local black bird will do it for you
You will have to wait until the birds have flown the nest
« Reply #2 on: November 11, 2024, 06:54:59 PM »
Practice your origami
Offline Athame57
« Reply #3 on: November 11, 2024, 07:00:47 PM »
Nah....much more a Robin's kind of territory!  ;D
1978 CB400F2 named Elen.
« Reply #4 on: November 11, 2024, 07:43:15 PM »
I just did the best I could with the wiring spreading it out radially using some tape to hold it in place, now that I have fitted a 500 standard rim with a Land Rover LED headlamp there is lots of room as the LED units are relatively slim. Not for the purists as I fiitted fork clamps as the 500 bowl is deeper, bonus is it's much brighter than the standard Candle  like lamp. I retained the original 400 bracket for added sturdyness.
400 lamp change 2 by Macabe Thiele, on Flickr
.400 lamp change by Macabe Thiele, on Flickr
« Last Edit: November 11, 2024, 09:07:36 PM by McCabe-Thiele (Ted) »
« Reply #5 on: November 11, 2024, 08:01:37 PM »
Make a hole in the centre of the birds nest to allow the bulb holder on the back of the light to fit in the hole. A Masters Degree in Spaghetti Arranging helps hugely.
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
« Reply #6 on: November 11, 2024, 08:46:55 PM »
Just push the wires & connectors back very carefully...ensure the correct fuse is fitted and switch on...!
I think the CB250/400N had a grid plate for the head light shell connectors?
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
