Author Topic: New Superdream problem - bit of a bodge?  (Read 7346 times)
Re: New Superdream problem - bit of a bodge?
« Reply #15 on: November 16, 2024, 04:32:19 PM »
Ted, the silver lable on the new one suggests to me its from a US model
The label is information about the exhaust system.
« Reply #16 on: November 16, 2024, 04:34:14 PM »
I wonder if it's from a CM400T or CM auto Ted?
The sd site say its from a CM400T auto as it has a chain protector built into  the end of the swing arm that was later modified.
« Last Edit: November 16, 2024, 04:36:46 PM by McCabe-Thiele (Ted) »
« Reply #17 on: November 16, 2024, 05:36:48 PM »
Yes the label is about exhaust but i think it was only on US bikes mate
« Reply #18 on: November 16, 2024, 06:45:05 PM »
That explains why it's in such good condition.
« Reply #19 on: November 17, 2024, 08:33:10 AM »
It's sounds like the 250RS swinging arm Ted... prone to bad corrosion. Luckily, on my RS the PO had worked at British Aerospace and had chromate primed and painted it with aircraft paint. Decent UK S.D. ones are rare then I would imagine. I had a '400F' one that was longer than the one on my bike and turned out it was from a CJ250 ... a friend who's bike/engineering skills I respect said ... 'Ooh can I have it for my 400' as he considered it would be an improvement on the standard one.
I would just use it as it's so nice, using a longer chain and you may even find the bushes are OK as it looks like it's from a low mileage bike.
« Reply #20 on: November 17, 2024, 09:08:51 AM »
Agree with Ash, it's well within small adjustment category for optimisation of a motorcycle chassis geometry too.
Far more subtle than length of shock etc as it won't alter static fork angle and geometry.
Modern method make use of moving the swing arm pivot to change wheelbase, alter squat and anti squat etc by the ability to move the pivot both vertically and longitudinally.
« Reply #21 on: November 17, 2024, 11:45:26 AM »
Thanks for all your imputs
I'm going to keep the replacement swing arm, it's in too good a condition not to, I will see if the supplier has a suitable chain guard. I could cut off the front bracket from the old arm, not sure rivetting a bracket in the right place is a good idea.
The old swing arm had rotted from the inside, presumably water gets inside somehow.
« Last Edit: November 18, 2024, 02:27:05 PM by McCabe-Thiele (Ted) »
« Reply #22 on: November 17, 2024, 08:59:28 PM »
I'm still a little undecided about returning my longer rear swing arm.
I've been looking at an issue that might arise with my existing chain being too short using the longer arm.
My 400NA bike has a 16T front sprocket, 36T rear spocket, standard chain is a 530-100L part.
The 250 version uses 15T/41T spockets  chain is  530-102L part.
At a glance the extra 2 links might sort out the longer chain needed.
« Reply #23 on: November 17, 2024, 09:17:26 PM »
Conventionally speaking, you can only alter the chain by 2 links (two pins, effectively) to be able to join it again.
This, conveniently, gives you the amount of extension you get by measuring one pin to another (or chain dimension chart) to see how much further you can position the wheel away from front sprocket.
« Reply #24 on: November 17, 2024, 09:40:22 PM »
530 chain is available in many different lengths, get one too long and shorten it, you grind the heads off the two pins on one side plate and it falls apart
« Reply #25 on: November 18, 2024, 11:28:13 AM »
Longer swing arm + a turbo = drag-racer 🙂
« Last Edit: November 18, 2024, 01:49:48 PM by andy120t »
Offline Rozabikes Tim
« Reply #26 on: November 18, 2024, 11:54:46 AM »
Longer swinger + a turbo = drag-racer 🙂
Or
« Reply #27 on: November 18, 2024, 12:47:46 PM »
I'm hoping mine will not be that extreme! ;D
« Reply #28 on: November 18, 2024, 12:51:59 PM »
I thought you said "an extra two links " Ted and not two whole chains  ;D
« Reply #29 on: November 18, 2024, 02:28:22 PM »
Imagine the length of the chain guard. ;D
