Author Topic: TEC shocks  (Read 19167 times)
Offline DomP
TEC shocks
« on: November 29, 2024, 03:38:49 PM »
The shocks on my 550 are...shocking!  I've found TEC shocks on Ebay with piggyback reservoirs, has anyone used them and can  recommend that I order resprung for my miniature 10st 7lbs?
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
Re: TEC shocks
« Reply #1 on: November 29, 2024, 04:23:43 PM »
I have fitted a set of TEC standard  chrome shocks
For the price, they look good and  very similar to the original,
But, the spring is very soft, I need to set it on the hardest for a normal ride, no adjustment for a pillion  ,also after a reasonable time, the damping seems to vanish, I can feel them bottom out over bumps,
But, cosmeticly they look good
Offline DomP
Re: TEC shocks
« Reply #2 on: November 30, 2024, 07:36:03 AM »
Thanks John, so probably about right for my weight really.
1975 XS650B
Offline Martin6
Re: TEC shocks
« Reply #3 on: December 03, 2024, 02:54:35 PM »
I used Hagon shocks on my 750. They look quite oem. I am very happy with how they transformed the bike. I'm 175lbs and I no longer bottom out the rear, no wallow and confident handling.
They do ask your weight before making up the shocks.
Re: TEC shocks
« Reply #4 on: December 03, 2024, 04:15:33 PM »
Only problem with Hagons, or rather Girlings as they used to be, was whilst they supplied different springs for the different models (750,550,500,400) the lengths were all the same which was not what Honda dif
Re: TEC shocks
« Reply #5 on: December 04, 2024, 09:41:30 AM »
I must admit that the Hagons definately improved my 750F1 handling compared to stock ones.
Offline Martin6
Re: TEC shocks
« Reply #6 on: December 04, 2024, 10:05:28 AM »
My Hagons were very slightly longer (couple mm) than what I took off (originals). I thought due to sagging old springs. The bike doesn't sag anywhere near as much under its own weight. So difficult to compare. Rides well though.
Re: TEC shocks
« Reply #7 on: December 04, 2024, 12:10:26 PM »
Strangely enough my Superdream is fitted with Hagons, nothing fancy just a normal looking damper no extra reservoirs or whatever they are called like on race bikes.
Re: TEC shocks
« Reply #8 on: December 04, 2024, 01:04:36 PM »
I have Hagons on my CB200
Look good, work well, quite firm,
Slight issue, they are about 2cm to  long
Making it difficult to remove the wheel without the standard exhaust getting in the way,
Offline Skoti
Re: TEC shocks
« Reply #9 on: December 04, 2024, 01:48:29 PM »
Fitted Ikons with adjustable spring pre-load and damping dial adjustment.
Top notch, but needed to dig deep into my pocket.
Ikon series 7610
Model SP1296SP8
Skoti
1976 Honda CB750F1
