Cable Routing
Topic: Cable Routing (Read 3864 times)
TezzerTel
SOHC Member
Cable Routing
November 30, 2024, 08:52:43 AM »
Looking at the cable routing diagrams in the files section it looks like the main wiring loom goes under the lower part of the triple tree/lower yoke? Is this correct?
Sesman
Re: Cable Routing
November 30, 2024, 09:26:33 AM »
Yes, that’s correct. There’s a cable clip positioned below the bottom yoke.
Last Edit: November 30, 2024, 09:29:43 AM by Sesman
TezzerTel
SOHC Member
Re: Cable Routing
November 30, 2024, 03:21:47 PM »
Mine has a tapping for a clip on the right hand side but the loom seems to go down the left hand side of the bike. Does the loom crossover?
Sesman
Re: Cable Routing
November 30, 2024, 06:55:33 PM »
Yes, indeed it does.This is to ensure there is steering ‘lock to lock’ length on the loom before it enters the headlight bowl. If you would like more piccies, I’d be happy to oblige.
Last Edit: December 01, 2024, 11:01:44 AM by Sesman
TezzerTel
SOHC Member
Re: Cable Routing
November 30, 2024, 07:23:12 PM »
Yes please more photos would help. I've clipped the brake light switch wires into the clip on the headlight bracket it seems like that's a sensible option. Also photos of the routing in around the plate where the fuse box is
Sesman
Re: Cable Routing
November 30, 2024, 07:33:43 PM »
More tomorrow…
TezzerTel
SOHC Member
Re: Cable Routing
November 30, 2024, 07:43:03 PM »
There helpful thank you. I wasn't sure if the lead from the main loom that goes to the top multi plug goes over the top and down to the plug or around the lower front and up
Sesman
Re: Cable Routing
November 30, 2024, 08:05:26 PM »
And this…
Cable Routing
